07-03-08, 06:57 PM | #61 |
Re: I've got the front end Bug!! Help!!
Just a quick question about wheel bearings. I brought a new GSXR front wheel and some new bearings, now how do i get them in the wheel. It's bloody tight, do i just give them a good few whacks with a mallet or is there a special way?
Cheers Rich
RIP Hovis - Unlucky Boyo
07-03-08, 07:14 PM | #62 |
Gently!
2 ways possibly, one is to use a bit of threaded bar and draw them in, other way is to grind down the inner of the old bearing and hit that. Or use a socket that will touch the OUTER of the new bearing and use that to drive them in. Make sure they go in straight, a bit of light grease and cleaning the bearing recess helps, lots of little taps don't beat the $hit out of it.
07-03-08, 07:28 PM | #63 |
I use a big socket, and a bigger hammer
09-03-08, 12:02 PM | #64 |
So a quick update, i'm getting there slowly with all the parts only a few things left really before i can get this show on the road. Brought a new wheel from delkevic because to get on in decent condition was costing as much as a new one from these. It's in white i know but thats all they had in stock for a while so i said i'd have it if they delivered FOC. Luckily i know a place close by that will powder coat it so no problems there.
Also this week my abba stand arrived, bloody great bit of kit paddock stands are a thing of the past now. And shortly to follow this week is a new set of solo course discs, can't wait things are coming together now. Watch this space Oh and ofcourse some piccys to keep you all amused.
09-03-08, 01:29 PM | #65 |
I see you have the GSXR 1000 forks and you have put the 600 brakes on it, have you got the wheel/discs to fit yet? I thought the 1000 only went to radial brakes on the K6, so if they are 1000 forks (black tubes) they shouldn't be K4? Please someone correct me if I am wrong but I also thought the K6/K7 1000 wheel was different, in which case you might have trouble getting the wheel/disc combination you want if you use 600 brakes. Only reason I know is that I have just done similar, tried to marry K4 600 forks/wheel to 1000 radial calipers (the black ones) and failed.
09-03-08, 02:02 PM | #66 |
GSXR1000 K4 and K5 came with radials, gold ones too which are what was on the GSXR600/750 K4 and K5.
09-03-08, 02:11 PM | #67 |
The 1000 went to radials first, in 2003.As long as the bolt width is compatible most radial calipers interchange- there's only really 3 sizes out there, which are more or less italian, japanese, and R1 6-pot. They also come in different "heights" (and maybe so do the mounts) which can be problematic, since frinstance my GSXR thou Tokico calipers effectively have a spacer built in, which means that on the K4 750 forks thy'll only fit 320mm discs (or larger). I don't have enough info to say exactly which are which though- but you get the most choice with a caliper and fork set that combines for 300mm, then you can always use bigger discs by spacing the caliper.
09-03-08, 02:48 PM | #68 |
Thanks, that's where I went wrong. I ended up with the black 1000 caplipers designed for 320mm discs and I either needed to change discs, or calipers. I changed calipers in the end which was not that expensive, there seem to be plenty on the market.
09-03-08, 03:06 PM | #69 |
I've been doing my research don't you worry. No i have GSXR1000 K3/K4 forks (same for both years) and GSXR1000 K3 Calipers. Heres a pic to prove it, the calipers are a different shape from K4 onwards abit more angular on the Mounting points.
You lot had m e worried for a moment there..
09-03-08, 04:52 PM | #70 |
How much did you pay for the front wheel?
Phil I'm not here for a long time, I'm here for a good time! Blue SV650 K3, GSX-R K5 front end, TL1000S clip-ons, lower fairings, seat cowl, gel seat, Pyramid undertray, R&G crash bungs, stainless steel bar ends, full titanium Akrapovic exhaust, Power Commander, clear rear light, flush mount front indys, mini rear indys, Autocom 300 duo intercom, Acumen cat 1 alarm and Micheline Pilot Power 2ct's. |
K3 front brake lever, Front indicator (RH), Front Mirror(RH), Bar End (RH) | leegriffiths128 | Stuff Wanted | 0 | 23-07-08 09:11 PM |
Front Discs (pair) for sv650 '99 curvy + Front wheel | mikeSV | Stuff Wanted | 1 | 28-05-08 04:21 PM |
Front Discs, For those with GSXR Front Ends on thier SV's | Ter | For Sale - SV's and SV related items | 2 | 14-03-07 12:56 PM |
SV650s 2000 model, yellow. I need front central and front right fairing. | OdySV | Stuff Wanted | 0 | 25-02-07 04:47 PM |
GSXR front end swap - front tyre profile. | Khewett | SV Talk, Tuning & Tweaking | 12 | 11-05-06 11:24 AM |
