#61 |
Nah, if all the spark plugs are out then the cylinders cannot lock it must be elsewhere. Make sure there is venting to the engine block by removing the oil filler cap before attempting to turn the engine.
Engines are fun ![]() Have you had a peek with a torch into the spark plug holes? Last edited by flymo; 22-06-09 at 09:06 AM. |
#62 | |
Have you pulled the plugs then?
#63 |
#64 |
Solved I think
Was having a think earlier on, started from my way back and solved it I think, the cog that rotates the shaft that's rotated by the starter, was jammed up against the casing, for some reason it wasn't located where it should be, gonna see if this cures it then if not, move on to other ideas. |
#65 | |
Once thats sorted try everything by hand with a socket on the end of the crank. If it all rotates fairly easily drop the plugs back in and we can proceed ![]() |
#66 |
Yeah, rotates say half a turn and then gets stuck again
#67 |
Grrrrrrrrrrrr, put her all back together, got it topped up with oil, connected the jump leads up to the starter motor as the battery is dead, one turn maybe and kaputt, jammed again
![]() In all the fuss trying to drain the old oil, I overtightened the drain plug being a **** and having the ratchet the wrong way. Doh! I have 2 other pans in the garage so not too much of a problem. |
#68 |
Hang on a minute, am I being a complete idiot here?
The battery is completely fudged, this is a fact. Does this stop the coils doing their job? Last edited by Stig; 24-06-09 at 12:21 PM. |
#69 |
If the battery is totalled how are you getting power anyway?
#70 |
Sorry Plowsie... too thick to make sense of your posts.
Were you saying that the starter goes whizz CLANK? If so and it's the same sort of starter as the 400 then it could be low battery. If/ but/ maybe & if you're even taking about starter Motors. There's a name for that type. Can't remember it. Yorkie Chris can. just string whiz, clank & starter motors into the same sentence. So far, so useless EDIT Ahhhh ignore the above then - if the engine aint turning you don't want to be hitting the starter.... Last edited by Sosha; 24-06-09 at 12:35 PM. |
help with uni project | TeddyBearKing | Idle Banter | 20 | 17-04-09 06:33 PM |
H*nd* project | DavieSV | Photos | 0 | 07-02-08 11:11 PM |
Londons Fastest Snail | scorpion | Bikes - Talk & Issues | 7 | 14-05-07 06:12 PM |
snail trails | poisonidea | Idle Banter | 16 | 07-01-07 11:21 AM |
What 'project' for £100 | glade | Bikes - Talk & Issues | 20 | 24-10-06 07:19 PM |
