#61 |
just looking at the fixer peg and looks good but at £19 its a bit steep any where that sells them cheeper ?
#62 |
Only available through the website I believe, but DavieSv who is a member on the site sells and makes them
http://forums.sv650.org/member.php?u=3738 The idea came after doing rideouts where somebody came off and broke a foot lever, and we had to cobble up a workable peg. This works perfectly. I believe he does offer a discount to Org members but I may be wrong. |
#63 |
ok cheers
#64 | |
Waste of time doing that , just take it easy for the first few miles on them and they will wear through the coating and release compound they have on them from the moulding process . As far as your shoulder goes , I have found over the years that they tend to stiffen up so I try and keep on the move by doing things like making a brew and avoiding heavy work with the affected area . Even when strapped up it paid to do a very light excercise to keep the muscles moving . Now this is not medical advice by any stretch of the imagination and should really be advised by a medical professional on a case by case scenario , so just pop into the Docs , mention you had a spill and get yerself a nice healthy supply of Co-Codamols for any pain . |
#65 | |
#66 |
cheers for both replys
#67 |
No you are right , it would not have helped at all , and from this thread I have decided I might as well throw my clutch lever under the seat as well . It has a broken Ball-End on it but it is better than no lever at all and I might source an emergency Brake lever as well . Oh I also have an emergency Soft Link for my chain as well under the seat .
#68 |
^ thats a lot of stuf under you seat lol, suprised u dont have tined beans and a gas burner
![]() i will take a pic of the lever later, and to be honest i realy dont fancy trying to stop with just my rear brake |
#69 |
I could probably squeeze them in as well with a bit of patience , I hardly use the rear brake , only if I have to . I spend more time keeping it free from seizure than I do using it which is the majority of the problem with it .
#70 |
lol i find the back brake prety naff :/ i have goldfren sintered pads and still find it prety bad but geting braided lines after christmas to see if that improves them, they did improve when i cleaned the cylinders and seals but not by much so fingers crossed a new bleed and lines/fluid will bring them back to life a bit
I Crashed. | Sean_C | Bikes - Talk & Issues | 29 | 02-01-08 11:32 PM |
Crashed but I'm ok | Warthog | Bikes - Talk & Issues | 49 | 13-04-07 04:18 PM |
Crashed | heros | Bikes - Talk & Issues | 15 | 23-02-07 04:10 PM |
crashed in to!!! | goldengraemes | SV Talk, Tuning & Tweaking | 50 | 11-04-05 12:57 PM |
