Old 26-01-10, 02:18 PM   #61
Stu
Trinity
Stu's Avatar
Default Re: Scary statistics for bikers in Wales
Originally Posted by Red Herring View Post
As for your comment about the R1 rider you seem to be completely missing the point. That clip demonstrates what can happen if you don't leave yourself time to stop, or others time to see you. The rider wasn't even in sight when the car driver decided it was clear and they could pull out. You can't expect someone to give way to something that isn't there...
IMO you've completely missed Ed's point!
Ed was not supporting the R1 rider, he was saying just like it's not the car driver's fault when he pulled out on the R1. The R1 should not be expected to crawl past the junction just in case the car pulls out
Old 26-01-10, 02:30 PM   #62
-Ralph-
Think they were talking about this bit.
The earlier you plan the more time you have to make a decision, there should be no such thing as an emergency stop, that means you didn't plan it!
Disagree... you can't predict the actions of some morons
As for crawling, well suppose that depends on how you define a crawl. Approaching a junction on a national speed limit road, I'd expect to be at or below the speed limit. With a visible hazard/threat at that junction, such as a waiting car, I'd expect to be between 40 and 50mph, but nearer to if not on 40. Highway code stopping distance is 120ft at 40mph, the reality is that is a distance designed for older cars, and a modern bike on a dry road does it in much less.
Is that crawling?
If they pull out when you're 30 feet away, you are still doing 40mph or 60 feet per second. They shouldn't have moved more than a couple of feet into your path in the 1/2 second before you have swerved and gone round the front of them. If they pull out when your 60 ft away, that's when you have to worry and start choosing an escape route, because you could be on the brakes hard and faced directly with the side of a car. If its a tractor and trailer completely blocking the road ahead that pulls out at 60 ft, start choosing the softest looking hedge to land in! If they pull out when your 100ft away, you should stop OK.
Even if you do hit something, you should be hitting it at a speed where you get up afterwards and thump the other driver
Old 27-01-10, 01:55 AM   #63
Red Herring
Red Herring's Avatar
Ralph, I like your style, you say what I meant in language even I understand....
Stu, you're right, I think Ed and I both got the point, just in different dialects...
Old 27-01-10, 02:00 AM   #64
fastdruid
fastdruid's Avatar
Originally Posted by tigersaw View Post
I notice in the collation of the statistics a fracture is considered a serious injury
Worse than that, a hospital visit is a KSI.
That's just a visit btw, you can be checked out and have nothing wrong.
Druid
Old 27-01-10, 02:08 AM   #65
fastdruid
fastdruid's Avatar
If the junction is to the nearside get out on the crown of the road (or further still) to give yourself as much room as possible, if to the offside then be ready to stop and start eyeing up gaps in the nearside hedge (I kid you not).
There is actually a secondary reason for moving over quite apart from giving more room, it vastly increases the chance of you being seen.
I don't have a link to the study but its been found that we are very bad at 'seeing' anything that is on a course to pass just slightly in front of us, just the act of moving from the centre of the lane to the outside (or nearside) could just be enough to alert a driver that you are there.
Druid
Old 27-01-10, 09:18 AM   #66
Druid
The eye is drawn to movement, and something coming towards you isn't "moving".
Being out at the crown of the road creates a bigger angular change as you approach meaning you're more obvious
Vital Statistics ThEGr33k Idle Banter 105 06-01-08 08:20 AM
wer do the sun get there statistics ? leemole Idle Banter 10 27-10-07 08:10 AM
Statistics! MiniMatt Idle Banter 11 01-06-07 08:36 AM
Bikers Retreat (North Wales) Moo The Good The Bad and The Ugly Pub and Cafe guide 2 06-04-05 02:40 PM
