Old 04-02-10, 11:32 PM   #61
beabert
Default Re: Regulator chat thread.
Looks fine to me, its the one ill probably be getting, yes on the live.
Old 04-02-10, 11:36 PM   #62
try vehicle wiring products for your stuff
http://www.vehicle-wiring-products.e...s/holders1.php
I would use part no 210 210C and 210P ... put small self-tapper into side of subframe to hold it.
Old 04-02-10, 11:38 PM   #63
beabert
Nice one, they look alot more professional.
Old 04-02-10, 11:40 PM   #64
5hort5
Sound, ok, just to double check:
  • Get RR
  • Get wires rated to 50amp min
  • Get fuse holder and fuse (20 map + 30 just encase)
  • Get circle clips to fit live and neutral to the battery (rated correctly and the right size for the battery bolts)
  • Get spade end connectors (rated correctly)
The job:
  • Chop the plugs of the lume, add spades to the yellow ones (soldered), tape up the red and black (or just leave the plug on them and tape that up)
  • make up yellow connect wires with spades (soldered)
  • make up live and neutral wires with fuse close (about an inch or two) from the battery, spades on one end, rings on the other.
  • plug it all together
  • start and prey (test)
Does that about sum it up or have I missed something?
5hort5 is offline   Reply With Quote
Old 04-02-10, 11:47 PM   #65
beabert
For the wire use the same wire as the inline fuse thing from maplin (12AWG), no need to get 50 amp wire if your using that.
Old 04-02-10, 11:48 PM   #66
Or you can get a fancy waterproof connector for your 3 yellows.
you know the pair of plugs with 4" of wire between them next to reg-rec? I cleaned one of those up so new reg rec would plug straight in to alternator.
It is up to you, many ways to skin a cat. So long as your connectors aren't green and fuzzy
Old 04-02-10, 11:51 PM   #67
beabert
Yes ill be axing that bit out too, might even go straight from alternator with a new run lol.
Old 05-02-10, 12:14 AM   #68
5hort5
nah - I'm drawling the line at going to the battery that'll do me
Old 05-02-10, 12:48 PM   #69
5hort5
ok, here is the beast it's a FH014AA from an 09 fireblade apparently. The first pic shows the size against the stock one and the second the pins.
So my main question is which pin is the live one? It's not marked with a hardy + sign, do you know the way to test to find out which on is which on the pair on the right?
Old 05-02-10, 12:50 PM   #70
Connect it up, start bike, use your voltmeter on it. If you get a +ve reading then you have your live probe to live terminal, if it is -ve then it is backwards.
Photo Comp - Chat Thread 5hort5 Photos 1254 15-06-20 04:13 PM
welsh TT weekend away (take 2) Banter / Chat thread hovis South & West Surfers 452 13-10-09 04:00 PM
North Wales Rideout #4 thread - Please use this for chat Luckypants The Border Patrol 287 26-11-08 09:44 AM
SV Ecosse Glencoe Massacre chat thread Lissa Rideouts & Meetings 66 23-07-08 01:30 PM
Booking chat thread. rictus01 2007 Annual Rideout 110 27-06-07 02:15 PM
