#61 |
For those that have a machine and learn to maintain it, fix the basics, clean it and look after it will slowly realise it is the most reliable. To those that dont .... Well it could be any bike .... They are exposed machines that run under extreme conditions. Expect them to need tlc.
Learn to maintain your bike, take it apart, rebuild the engine & more (using better bolts ![]() K3 Job c.v: Engine:remove/split/rebuild/refit. Replace:Gearbox,Fuel pump,Gaskets. Piston clean,rings. Overhaul:Throttle body,Injectors,Brakes,Forks. Remove/refit:Exhaust,Radiator,Oil cooler,Throttle,Air filter,Tank. Replace: Oil,Coolant,grease,brake hoses & bleed. |
#62 | |
When you have 30 to 40 items a day going out time is an important factor. I know boss-man won't sell it whole for reasonable money because I tried to buy it myself but he wanted way over the odds considering the age etc, he'll break it for far more than he offered it to me. |
#63 | |
Good morning all. Indeed the components themselves are pretty reliable. It's the bits between them that aren't! The gauge of wire used would insult a two bob Taiwanese radio, & the lack of waterproof connectors, which leads to corrosion, can, cause reliability issues. Cheers. Last edited by Spanner Man; 22-11-11 at 07:19 AM. |
Manufacturer coaltion? | muzikill | Racing and Paddock Chat | 2 | 06-11-11 02:25 PM |
Sat nav or car most reliable | Messie | Idle Banter | 10 | 31-03-09 12:34 AM |
Single Tyre Manufacturer in Racing - Good or Bad | Scoobs | Idle Banter | 16 | 18-08-08 10:45 PM |
Car manufacturer to challenge congestion charge | Dicky Ticker | Idle Banter | 0 | 19-02-08 05:22 PM |
Manufacturer recommendations? | lukemillar | Tyres | 0 | 14-03-07 11:55 AM |
