Old 23-03-19, 09:55 PM   #7151
Sir Trev
Sir Trev's Avatar
Default Re: Gripe of the day - What is yours?
I had the same advisory two years in a row on my GSX. Our old friend Spannerman serviced it and when he looked he said (in a very gravelly voice between rollups) "it's fine Trev". Third year and the very same MoT centre never mentioned it...
Whenever an MoT tester says something needs doing I always get a second opinion.
Sir Trev is online now   Reply With Quote
Old 24-03-19, 08:34 AM   #7152
admin
John T
admin's Avatar
Yep, this guy also says there's play in the rear suspension linkage and it'll need a grease up. He used to say the same about my SV. It'll be interesting to see what he says this June.
Someone told me that they need to put something down on the mot report to make it look like they've done a thorough job as their work is assessed.
Sent from my Nexus 7 using Tapatalk
Old 24-03-19, 09:05 AM   #7153
Luckypants
Luckypants's Avatar
Originally Posted by admin View Post
Last June the mot mechanic mentioned my rear pads are a bit low. So the other day whilst ordering a new air filter I also ordered new pads.
Today I took the rear caliper off to check wear since June and guess what, yep, loads of material still left. Given my low annual mileage I can see my new pads sitting on the garage shelf for another year.
Yet mine go the other way.... My rear pads wear much faster than they used to on my previous bikes. It's due to the linked brakes on VFR, rears come on when using the front.... Still only needed replacing every 24K miles though.
This has always come up from tine to time on my VFRs. Never needed to do anything.
Old 24-03-19, 09:21 AM   #7154
admin
John T
admin's Avatar
I assumed the same thing about the linked brakes. Normally I would have checked before ordering but that meant taking the wheel off and I was being lazy.
Sent from my Moto G (5) using Tapatalk
Old 24-03-19, 10:19 AM   #7155
Adam Ef
Adam Ef's Avatar
I had rear pads advisory on my SV. I fitted new ones a year later and was fine.
Old 24-03-19, 11:39 AM   #7156
admin
John T
admin's Avatar
Mot tester, 'There's only 10k miles or so left on those pads sir'.
Me, 'So another 2-3 years before I need to change them then'
Old 24-03-19, 01:42 PM   #7157
Adam Ef
Adam Ef's Avatar
And that's if you use the rear brake as much as the front brake.
Old 24-03-19, 02:12 PM   #7158
admin
John T
admin's Avatar
I hardly used the rear on the SV. I don't have a choice on the VFR
Old 24-03-19, 04:13 PM   #7159
Heorot
I use the rear and engine braking much more than the front. The front is for when I REALLY need to stop. Like yesterday when a Harley rider pulled out from a side road, saw his mate stopped on the verge and then hit his brakes while still side on to me.
Some say the cup is half empty, while others say it is half full. However, both are wrong; the real problem is the cup is too big.
Honda 125 CG blown engine Gone to the great mechanic in the sky
Naked SV650 K3 in Silver
Heorot is offline   Reply With Quote
Old 24-03-19, 11:56 PM   #7160
BanannaMan
BanannaMan's Avatar
Had planned on the years first real ride out on the bike.
Got her all ready last weekend.
The bike is right.
The weather is right.
But the rider was not.
Turned around at the first intersection and came back home.
Apparently have injured the ankle again on the broken leg (from 16 months ago) that I'm still recovering from.
I knew it was swollen but didn't realize I wouldn't be able to bend it far enough down to get under the shifter.
I managed to get it back home using the edge of the sole on the side of the shoe to upshift.
Guess Spring will have to wait a few more weeks.
...Bill
whats ur biggest gripe about the uk? kwak zzr Idle Banter 101 15-11-16 06:33 PM
heated grips gripe adw Bikes - Talk & Issues 8 12-05-10 02:48 PM
