Old 05-05-09, 10:25 PM   #71
davepreston
Default Re: fish tailing like mad
So did Dave check his tyre pressures...?
in that case I'll probably see DaveP on the Ar09 in 2011....
listen here R.E.M.F boy unlike your lot i do on time where needed lol
Old 05-05-09, 10:51 PM   #72
Richie
fantabulas
Richie's Avatar
catch you soon.
My Flickr photos
Old 06-05-09, 06:59 AM   #73
Baph
I know the thread has been answer, but I had to pick up on this...
Originally Posted by TazDaz View Post
If you knock it down a few gears whilst on the front brake, if the revs happen to bounce high enough it may spin the wheel up a bit which can feel weird.
It can do, yes, more in a sec...
Whats driving the wheel in that scenario ?
How do you spin the wheel in the direction of travel ( which is what I think you are impying ) when the throttle is shut and no fuel is being admited to cylinders to burn to move the bike forward.
Cant see what you're getting at...
Fizz, I'm sorry but that's a rather large assumption. At no point (that I can see) did anyone say under braking the throttle was shut.
Supermoto technique's mean you can ride a bike where you're heavy on the front brake, whilst actively opening the throttle. I won't go into detail as I would hate for someone to read this & think "That sounds like a good craic, I'll try that."
It will step the back out going into a corner, and it takes a certain element of bravery the first time it's attempted. Then you need to pull over & change your pants.
Sorry, I'll go sit in the pedantic corner now...
Old 06-05-09, 08:15 AM   #74
fizzwheel
fizzwheel's Avatar
Yep but a reasonable one I think.
I for one dont ride along with the throttle pinned open and the front brake on...
Old 06-05-09, 08:35 AM   #75
Baph
[pedant mode]You don't do it with the throttle pinned open, on an SM bike, that would result in an interesting wheelie when the tyre grips mid bend. That's part of the reasoning I didn't go into detail in how to accomplish it. [/pedant mode]
I learnt the technique on a friends KTM, and regularly do so when I'm playing, even on the SV. I find it allows for a faster paced ride, though I will conceed that it is vastly more dangerous (esp on public roads).
But you go through rear tyres too quickly.
Old 06-05-09, 10:25 AM   #76
Magnum
If you're hooning down the road, apply the front brake so the weight is on the front, but at the same time knock it down a few gears which will cause the revs to shoot up. Won't this cause the rear to try and spin quicker than the front???
If anything it would slow down the back wheel. Thats why you downshift to slow down, the gears can do some of the braking for you. When my bike jumps out of second sometimes it feels like i just slammed on the rear brake.
Old 06-05-09, 10:27 AM   #77
Alpinestarhero
Valentino Rossi has said that he uses a similar method, or has used a similar method, to help settle his motogp yamaha in turns. Ok, thats valentino, but the physics is still the same. I can see how it would work
Old 06-05-09, 10:36 AM   #78
Paul the 6th
Paul the 6th's Avatar
glad to hear you've sorted the tyre dave - was worried I'd have to do the recce on my own....
Old 06-05-09, 08:03 PM   #79
-Ralph-
A slide, yes. A lock, no
Take some extra sandwiches, a big flask, two packets of crisps and two Mars bars. YC will be waiting for you when you get there
Fish (not food!) pencil shavings Idle Banter 17 19-10-08 05:11 PM
fish and chips AndyBrad Idle Banter 36 10-10-08 07:25 PM
FAO Fizzy Fish!! rigor Soho Massive 2 05-09-07 10:55 AM
Anstruther Fish Bar The Basket SV Ecosse 10 25-06-07 06:06 PM
Anyone keep tropical fish? Mark_h Guildford Massive 31 18-04-07 12:36 PM
