Old 19-04-12, 04:21 PM   #71
embee
embee's Avatar
Default Re: Potential pointy Adjuster Plates Group Buy
...I take it the 5mm is the recess hight from the bottom of the trough to the top edge before it falls away on the angle?
Not sure of the depth of the "channel" in the swingarm, I just used some 5mm thick s/s plate I happened to have in stock.
The other thing I've just remembered is that the head end (brake side) plate bore has a chamfer to clear the underhead radius of the spindle, whereas the nut end has a plain bore just with the edge broken. I don't have any pics of the plates alone unfortunately, but it's all pretty self-evident if you come to do something similar.
Old 19-04-12, 04:31 PM   #72
muzikill
muzikill's Avatar
i'll do some sums and get back to everyone.
i don't mind being left with a few to sell on the bay or on svrider so it's getting near the possibility. as you can understand it's all about cash flow.
Bibio im sure people through the months will ask for these. Sell some on ebay to test the water. I bet they fly out the door. I cant wait until someone at an official suzuki garage spots this mod fitted on someones bike.
Old 19-04-12, 04:45 PM   #73
Jayneflakes
Jayneflakes's Avatar
Originally Posted by federer View Post
If there is a enough call for a SW postage group I'll join in or organise it.
Hey you, I am happy to pay the postage for mine and you can have yours chucked in with mine, I am quite likely to see you at Bike Night or can even pop them down to Scallys for you? entirely up to you.
ok i have done a few sums. from 25 people onwards i will start the ball rolling and do them for the original price of £12. the rest i can sell on the bay at an inflated price to offset the waiting time.
sooooo. i'll get a move on with this and hopefully you should all have them in your grubby paws within a month.
The tutoro unit is so simple, it really is just a pipe and a nozzle. So yes, I would like to have the oiler plate too, thank you kind sir. I may even make another daft video of me fitting it!
I showed the pic of them to the wife, she was suitably impressed and told me to go for it, I love having a wifey who understands the need to bling up my bike!
Jayne you're a Pussy Magnet
Old 19-04-12, 04:49 PM   #74
Artful
Artful's Avatar
Me too
No..Name................Type....................Po st to
1...joshwalker094.......Non-Scottoiler, with hole - Post to Nobbylad
2...DarrenSV650S........Scottoiler, not bothered if it has a hole or not
3...Epic Monkey.........
4...MJC-DEV.............Non-Scottoiler
5...Nobbylad............Scottoiler, with markers - Post to Nobbylad
6...muzikill............
7...The Guru............Non-Scottoiler. With markers
8...The Guru............Non-Scottoiler. With markers
9...fluffer.............Non-Scottoiler
10..Kilted Ginger.......
11..Turner..............
12..Jayneflakes.........
13..SIII................
14..peterco.............
15..tetol...............
16..twinset.............Non-Scottoiler
17..Davy.h..............??
18..Speedy..............Non-Scottoiler
19..Shawthing...........Non-Scottoiler. With markers - Post to Nobbylad
20..Sputnik.............
21..Elliott Woodruff....Non-Scottoiler - Post to Nobbylad
22..Steve_God...........Scottoiler version - Post to Nobbylad
23..SirBarnz............Non-Scottoiler
24..federer
25.originlabs..........Non-Scottoiler. With Markers
26. Artful
Artful is offline   Reply With Quote
Old 19-04-12, 05:11 PM   #75
yup one of the problems that encountered except the pointy need more of an edge to be taken off on the sprocket side.
yup. haven't even tried svrider yet but knowing the yanks they'll go nutz for them
yey even more compliments
Old 19-04-12, 05:42 PM   #76
muzikill
muzikill's Avatar
6...muzikill............... All the extras
24..federer
26. Artful
Im going to a fit a Tutoro to mine so ill post how it goes. Im sick of lubing the chain manually.
http://www.tutorochainoiler.com/inde...rcycleproducts
Old 19-04-12, 05:52 PM   #77
Davy.h
17..Davy.h..............Non-Scottoiler
24..federer
26. Artful
Old 19-04-12, 08:18 PM   #78
speedyctr
speedyctr's Avatar
24..federer
26. Artful
27..Speedyctr.........Non-Scottoiler
speedyctr is offline   Reply With Quote
Old 19-04-12, 09:01 PM   #79
Kirkybhoy
Kirkybhoy's Avatar
put me down for a pair pleeez..
Where are you getting them cut / formed. might be able to get you a price locally (hopefully cheaper for you as well )
The World Is Full Of Kings & Queens Who Blind Your Eyes & Steal Your Dreams..
Kirkybhoy is offline   Reply With Quote
Old 19-04-12, 09:10 PM   #80
i'm just needing laser cut as the forming/fettling i can do myself...
are you thinking of fifab?
potential pointy ecu restrictor kit bargain haydensv650 Stuff Wanted 0 18-08-11 07:40 PM
Replacement chain adjuster plates? SV400Rob SV Talk, Tuning & Tweaking 13 02-02-11 09:30 PM
chocolate chain adjuster plates dmracing SV Talk, Tuning & Tweaking 6 01-08-09 09:23 PM
Chain adjuster plates dmracing Stuff Wanted 6 24-07-07 05:54 PM
Stainless adjuster plates.....................bling svrash SV Talk, Tuning & Tweaking 19 23-04-06 07:22 PM
