Ancillaries Post your own reviews, opinions and experiences on various other bits and bobs, such as rearsets, oil, engine bits.
Old 22-09-20, 07:33 AM   #71
CheGuevara
Default Re: Bargain Alerts Thread!!!
Not really a bargain per se, but in case it's useful to anyone, I've got a generic 10% off code for M&P.
PC10D2020
Used today so it works. There's no end date printed on it, and it "excludes sale items".
- K9 SV650S: Hel brake lines, carbon end can
- SZR660: The project...
- K5 SV650S: K7 GSXR750 front end, ZX6RR shock, GB Moto rearsets, Hel brake lines, Renthal risers, Tuono bars, V-Rod headlamp, "JMV" belly pan ~SOLD~ (wonder where it is now)
CheGuevara is offline   Reply With Quote
Old 13-02-21, 07:40 PM   #72
yokohama
Maybe this of use to someone after a new helmet or accessory.
https://www.racevisors.co.uk/ have a 15% site-wide discount on at the moment,. (code 15NOW)
I just ordered a new visor and pinlock insert to extend helmet life for another couple of years.
Old 20-07-21, 04:00 PM   #73
CheGuevara
Unior 1/2" drive socket set- £18.68
Shows temporarily out of stock, but available to order so might get lucky
https://www.amazon.co.uk/dp/B004XVQF...omicindustr-21
Old 20-07-21, 04:39 PM   #74
SV650rules
Notice that socket set is 'unisex'...
Have to say it is cheap but I hate those double hex sockets that hardly touch the corners of nut of bolt head...
2016 SV650 AL7
Old 20-07-21, 05:05 PM   #75
DJ123
DJ123's Avatar
A bargain, if you like rounding bolt heads.
BMW F800ST
Old 20-07-21, 05:41 PM   #76
CheGuevara
I have an, err..."large" selection of good quality European and Japanese tools/socketry, with both 12pt and 6pt sockets. I've never had an issue with 12pt providing the tolerance is decent and the bolt/nut is clean and not already butchered. Even badly rusted/seized stuff will tend to break the bolt before the socket lets go and rounds the head of the bolt (clean is important - take a moment to scrape away any rust or grime that might cause the socket to ride up and/or not engage properly).
Most ring ends of spanners are 12 point, and most modern 6-point sockets are flank drive anyhow so only engaging a small surface.
I'm sure I saw a test of 6-pt Vs 12-pt and the conclusion was there was little if any difference in the amount of torque you could apply before failure.
Old 20-07-21, 06:23 PM   #77
CheGuevara
Couldn't find the article, so for fun I've stuck an M10 grade 8.8 bolt in the vice and used a Facom 12pt and 6pt socket (Facom because I have both and the tolerance feels about the same), size 17mm. I went to 130nm and no perceptible difference. No marks on either tool and no damage/deformation to the bolt head. I think that's more than double the typical torque for that size/grade bolt.
I appreciate it's not scientific, but hopefully at least suggests that a 12pt doesn't spell doom on that virtue alone.
Old 20-07-21, 09:29 PM   #78
Dave20046
Dave20046's Avatar
https://www.aldi.co.uk/search?q=Dry%...4cde0e0cc98f8f
These waterproof duffle bags are so useful for longer trips if you're not a full lugguage and his and hers matching leathers sorta person...
Live Flood Alerts DJ123 Idle Banter 4 07-07-12 10:13 PM
Spontaneous Rideout Text Alerts??! ceeshaw Guildford Massive 28 08-04-10 04:00 PM
Someone just got such a bargain... northwind SV Talk, Tuning & Tweaking 3 26-06-05 09:18 PM
