Old 11-05-10, 10:24 AM   #801
jaymee
Default Re: "33bhp?" Yes "i dont believe you, I'll seize your bike and take you to court"
My r6 had a label on he frame saying it was restricted and made 25kw @ so many rmp and was at blah dB. It was an fi international kit.
Old 11-05-10, 10:25 AM   #802
God I bet that ran like a bag of sh*t!
Old 11-05-10, 10:28 AM   #803
jaymee
I was great! No problems at all
Old 11-05-10, 10:37 AM   #804
Was it carby one orEFI?
EFI one I saw ran stupid rich with the FI int kit.
Old 11-05-10, 10:41 AM   #805
jaymee
It was efi, my only problems with running rich was that the tps went, but that could happen anytime, once it was replaced it was fine again.
Old 11-05-10, 08:09 PM   #806
mrcool
Originally Posted by Red Herring View Post
How about something like a DRZ then. That's quite a popular bike with new riders and they must make somewhere around the 33bhp mark yet weigh in at less than 150kg? To be honest the power to weight aspect hadn't even occurred to me and I'd wager 99% of other coppers wouldn't have a clue either.
I believe they are specified slightly higher than 33bhp (40bhp), but I read of someone online who rode for 2 years no prob. becuase he was adimant that it made less than 33bhp on the dyno at the wheel, which it probely did.
Old 11-05-10, 08:16 PM   #807
mrcool
It will work as well as an FI International kit, as long as you have an idea of where to start with mounting it safely on the throttle mechanism and methods of machining the stop to such a standard that it stays in place etc. Personally, I'd develop an adjustable one using something like a throttle idle adjuster screw to go on the upper reaches of the throttle travel so you can tweek it down to 33 bhp on the dyno without having to strip the bike down, rather than mucking about taking the fuel tank off off, adjusting it then refitting the tank every time.
You won't need any certificate to carry, but at a push you could produce the dyno printout to show the coppers - that's got to be worth 100 times more than any certificate to anyone.
With a 1979 Z500, I think it might just about scrape 33 bhp as standard anyway, if you're lucky. They weren't quick when they were new, and they certainly haven't got any better over the last 31 years. You may be wasting time even trying to make a throttle stop, so just stick it on a dyno and see what the bhp is as it stands now.
Aye, it may well make 33bhp or less on a dyno. The issue is it is specified as 50bhp, I don't suppose this matters tho, as all the law says is it must make <33bhp? I guess a dyno printout would suffice as proof. I do have to tell my insurers wheter it has been 33bhp restricted or not when taking out the policy, but if it makes less than this, I guess it don't matter.
Old 11-05-10, 10:05 PM   #808
Red Herring
Red Herring's Avatar
According to Google a DRZ SM weighs in at 134kg and makes 40bhp. To qualify to be ridden by a new rider the motor would have to be restricted to 28.7bhp...... Perhaps I ought to make a name for myself by finding one to seize and dyno....and weigh!
Old 11-05-10, 10:07 PM   #809
mrcool
But what is the accepted weight measurement, is it dry weight, wet weight or weight inc. rider?
Old 11-05-10, 10:29 PM   #810
timwilky
timwilky's Avatar
Mr Herring, you are making mischief. You are already adding additional parameters into the equation. When the professionals are saying you (certain police officers or their command structures) don't know how to measure power in the first place.
Now you add an extra dimension and I guess nobody knows how to measure that either.
Not Grumpy, opinionated.
eye ball yellow "n" and a blue "s" curvey!!! cymroboi The Border Patrol 5 19-06-09 08:09 PM
Using "Pointy" Tensioners in a "Curvy"? dtr125 SV Talk, Tuning & Tweaking 25 05-02-09 05:42 PM
that childish "but i dont want to go feeling" 454697819 Idle Banter 11 06-01-08 10:07 PM
Rideout "Sections" or "Groups" independentphoto Bikes - Talk & Issues 19 04-09-07 01:08 PM
