Old 24-07-16, 01:14 PM   #871
Red ones
Red ones's Avatar
Default Re: What have you tinkered with today?
Originally Posted by Sir Trev View Post
My pedals (on the push bike). They have survived 18 years of use but the oe pedals have seen better days. One was getting pretty loose on its spindle and the other makes scrunching noises at random suggesting a bearing or two are unhappy.
Explained my meagre riding habits and simple Raleigh hybrid commuter steed to the chap in the only remaining independant cycle shop in town as well as my (possibly mad) thoughts about trying toe cages and he suggested some simple looking Oxford jobbies that came all bolted together. It only took a bit of swearing and a hammer to get the old ones off and the new ones were on in time for a trial run to the pub. The straps will take a bit of getting used to but so far so good.
Never look back from toe clips. I've worn them for 30+ years, even with my kids (just done a 6 mile ride with the 6 year old daughter). Be prepared to replace the straps annually, the fastenings loosen off with time.
I actually prefer cages to the Shimano cleats I have on the other bike.
Old 24-07-16, 01:14 PM   #872
Red ones
Red ones's Avatar
Default What have you tinkered with today?
Prepped the SV for its MOT on Friday. Seems fine. 7 years old, 42,000 miles on the clock.
Old 25-07-16, 03:18 PM   #873
Teejayexc
Most cyclists don't seem to look anywhere
Old 25-07-16, 04:25 PM   #874
garynortheast
garynortheast's Avatar
Day in the garage yesterday, quick service for the curvy. All the fairings off, new iridium plugs, K&N air filter out and cleaned/re-oiled, carbs re-balanced, throttle cables and linkages oiled and adjusted, chain adjusted. Then a serious clean.
Rode it today and it's like another bike. You get used to it running a bit rough over time and this put it back to where it should be. Pulls like a train, light, smooth throttle action, ticks over like a watch. All the snatchiness and missing gone completely. Lurvely!!
Old 31-07-16, 04:31 PM   #875
aj76
So had a tinkering Sunday today, as bike had brand new chain and sprockets when I picked it up checked and adjusted the chain, changed the bulbs for Philips xtreme visions Inc sidelights and done the TPS mod and lubed throttle cables. Whilst seats were off found a little gift of grab rail infils hidden under the seat
Before
After
'gift'
Sent from my C6903 using Tapatalk
aj76 is offline   Reply With Quote
Old 31-07-16, 08:03 PM   #876
Happy days, rare as them rare things
Old 31-07-16, 08:35 PM   #877
Craig380
Fitted NGK Iridiums, then a 90-mile test ride. The standard CR8s had done 6000 miles and looked hardly used, the gaps were still bang on 30 thou so I wasn't sure if the Iridiums would make any difference. But they did: trickling along in traffic is smoother and less lumpy, and the pick-up is definitely sharper from light throttle at any speed.
Old 31-07-16, 09:11 PM   #878
tom_e
Tried to sort my slightly twisted forks, made it worse. Bike now handles like a bag of crap should have left it alone! Will have to give it another go and hopefully make a better job of it.
Also discovered some stiff links so new chain is on it's way.
Old 01-08-16, 02:48 PM   #879
NTECUK
NTECUK's Avatar
Orders a set of pattern rear pads for the Tiger.
Will do a review of them after I've tried in the wet.
Old 05-08-16, 05:40 PM   #880
dupont64
I ordered some 2K aerosols to respray my replacement (black) tank Canyon Yellow. I used a Pantone book to find the nearest match and chose Pantone 1235. RAL 1003 Signal Yellow is pretty close too. 2K aerosols contain a separate chamber of hardener which you activate with a button and then have to use the can within 8 hours. Supposed to be petrol-proof. Fingers crossed!
Been got already today.. 454697819 Idle Banter 16 01-04-10 02:08 PM
Today DaveP The Border Patrol 4 02-03-10 10:52 AM
Going out today? tj2 The Border Patrol 1 01-06-09 09:22 PM
Today Tara Guildford Massive 14 02-06-08 11:56 AM
Today...... Caddy2000 Idle Banter 15 19-04-06 05:39 PM
