Old 30-08-12, 06:53 PM   #81
monkey
Default Re: Help, I've screwed up the bottom shock bolt
Could there be washers missing from inside the dogbones?
Old 30-08-12, 07:04 PM   #82
hongman
I was just discussing this with my landlord.
If I could put a washer on each dogbone bolt it would give me enough clearance. The washer would need to go on the inside face of the dog bone but as long as it was a decent fit washer, I reckon that would do it.
What say the org?
The dogbones current do not have any washers, are they supposed to? I didnt think so because the nuts are flanged.
This could be an easy and importantly inexpensive solution.
Old 30-08-12, 07:13 PM   #83
have you tried turning the bolt the other way?
it also may be that the shock is not central and is over to one side on the bearing.
kawasaki nut and bolt. this is known to fit perfect as the nut is a lot more shallow.
part numbers, Nut - 92210-0321 Bolt - 92153-1546
Old 30-08-12, 07:49 PM   #84
hongman
The kwak bolt 100% fits the Nitron shock?
Old 31-08-12, 11:16 AM   #85
hongman
Need info asap if possible - anyone know how many mm thick the bottom bolt is?
Bike is at home and I want to visit a hardware shop today if possible.
Old 31-08-12, 11:37 AM   #86
i haven't used one but its a common one when doing shock swaps for curvy and pointy.
i don't know how your bolt is touching the dogbone as the bearing spacer is the same size as the pointy and mine is fine.
i'll ask the question again. have you tried turning the bolt round the other way?
if i don't fit the bolt the other way it fouls the dogbone, don't ask why as i haven't a fekin clue as it should make no odds but it does.
Old 31-08-12, 11:49 AM   #87
hongman
No Bibs, I haven't tried this one the other way round I don't think! I will try again tonight though as long as it isn't raining.
I called Nitron and he suggested that also. Again, he said that is what he's had to do with some bikes.
Uploaded with ImageShack.us
Old 31-08-12, 11:53 AM   #88
hongman
By the way Nitron said they now also do a clevis which is identical to the OEM shock - i.e thread built into one side of the clevis.
If I have no joy with turning it around he said they'll swap it for me
Old 31-08-12, 12:02 PM   #89
hallelujah. nitron have finally seen sense. get them to swap out the clevis
only downside is that you will have to send shock back to nitron and wait
Old 31-08-12, 12:04 PM   #90
hongman
You mean they wont come to my house and do it as I wait?
P1sstakers.
ZX9 or 10 bottom suspension bolt DaveW_42 Stuff Wanted 0 21-05-10 11:29 AM
what shock bolt ? barwel1992 SV Talk, Tuning & Tweaking 2 06-10-09 11:04 PM
K5 gsxr thou shock going onto k5 pointy - will I need the lower gsxr shock bolt? Paul the 6th SV Talk, Tuning & Tweaking 37 31-10-08 12:26 AM
M10 55mm Shock bolt and nut for Kwak Shock Mr Speirs Stuff Wanted 3 24-10-08 12:00 AM
rear shock nut and bolt for a diff shock drag Stuff Wanted 0 22-04-08 03:52 PM
