22-01-07, 11:57 PM | #1 |
Nikko g pack???
http://www.performancemotorcyclepart...kko_gpacks.htm
Anyone have this? does it derestrict top end or accelaration? Thanks john |
23-01-07, 12:04 AM | #2 |
The Sick Man
Nop & Nop
It basicly just removes a limit on the ECU or CDI unit that retards the ignition in 2/3rd gear to pass noise regs. Just search the TPS mod as its free and does the same as the G-Pack. ps. Some people say the G-pack does more but not prooven as no one knows whats realy inside the G-pack but its not worth the money and the TPS is free and does the same as far as people know.
OTR: KTM 690 Duke R 2015 Full Akro SIDELINE: Kwak ZX636 A1P 2002, Red, R&G's, Yoshi, Double Bubble Screen GONE: Kwak ZX-7R P1, Full Akro, Undertray, Screen GONE: SV650S K2 Very Bruised & Without Fairing, Motovation Frame Sliders, R&G Ally Sprocket Toe Protector, HEL 2 Line Setup, GSXR K1 600 RWU Forks, Barnett Clutch & Springs, Penske 8981 Shock, Gilles Ti Rearsets, Steel Barends, Scottoiler, AFAM Chain & Sprockets, Twin FIAMM Horns, Skidmarx Bellypan, Full Micron Zeta Steel System, Cut down undertay. Forum Problems & Information / Site Suggestions |
23-01-07, 12:14 AM | #3 |
The TPS (throttle position sensor) is different, that is just when the computer decides to put some fuel into the engine, which can be adjusted to lower revs to help with smooth slow riding...
I think you mean the TRE (timing retard emiminator) which does the same as the g pack by derestricting in gears 2 and 3. can be done a number of ways cheaper or free, just search for it, or them both for best tuning! Northy will correct me if I'm wrong, he's the 1 in the know. |
23-01-07, 12:26 AM | #4 |
can both of these be done on the curvey model?
23-01-07, 12:29 AM | #5 |
no, just the TRE i think, but its a different mod from the pointy, so make sure u get the right 1.
23-01-07, 12:31 AM | #6 | |
23-01-07, 12:36 AM | #7 | |
The claims made for the Nikko G-pack are not substantiated by my, (not very sensitive), dyno, and, ('cos I've examined the way the iginition system works, and made some accurate measurements too), I cannot see how it could do anything that disconnecting the GP switch wires doesn't. I really wouldn't spend money on one.
23-01-07, 01:06 AM | #8 | ||
TPS is this and only on a pointy, cannot be done on a curvy, due to lack of fuel injection, has nothing to do with the timing (below) or the g-pack TRE is this 4 a curvy as svrash said |
23-01-07, 01:13 AM | #9 |
The curvey does have a TPS, it mounted on one of the carbs. The curvey has 3 ignition maps dependant on throttle postion.
Saying that, i think TSM did mean the TRE mod and wires have been crossed |
23-01-07, 01:15 AM | #10 | |
Nikko racing G-Pack | toadie | For Sale - SV's and SV related items | 7 | 09-09-08 12:04 PM |
Nikko Racing G-Pack | DoubleD | SV Talk, Tuning & Tweaking | 2 | 19-11-07 04:50 PM |
Nikko G-pack For Sv650 2000/y | SAMMY650 | SV Talk, Tuning & Tweaking | 5 | 03-10-07 04:18 PM |
nikko g-pack | 01 sv650s | SV Talk, Tuning & Tweaking | 10 | 19-12-06 07:19 PM |
Nikko G-Pack for K3 Sv650 | Khewett | Stuff Wanted | 0 | 30-06-06 10:56 AM |
