01-10-19, 06:08 AM | #21 |
Re: Underwater SV
powered my underwater SV up and no smoke or surprises! Even the speedo seems to work and it tried to fire but has now given up. Ive probably got lots of codes to check as the FI is showing and Ive got lots of things disconnected still....
02-10-19, 12:56 PM | #22 |
Re: Underwater SV
Have you drained and flushed the fuel tank? Also replace the fuel filter.
If you get it running, plan on stripping and cleaning/replacing:
02-10-19, 05:52 PM | #23 |
Re: Underwater SV
surprisingly the water appears to have avoided the tank! I think it acted as a bubble because the vent pipe comes out the bottom so the fuel and air in the tank just sat there.
If it runs then I realise there will plenty of other jobs to do but will only start on them once Ive confirmed its alive.... |
02-10-19, 08:05 PM | #24 |
Re: Underwater SV
I wouldn't bother using the fuel that was in the tank, even if you think it's OK. Even a little bit of water in there will stop it running as it sits at the bottom and will be the first thing drawn into the fuel pump when you try and start it. Put new fuel in, disconnect the outlet pipe from the fuel tank to the injectors, and power up the ignition so the fuel is squirted out of it (obviously point it into a suitable bottle/container). You may need to drain the rail to the injectors if you're already tried firing it. Despite all the doom and gloom opinions you're actually in with quite a good chance of saving it given how soon you're started. Don't forget brakes. If the master cylinders have been under water ideally you ought to drain and replace the fluid but at least take the tops off and use a syringe or pipe to suck the fluid out of them before topping them back up with fresh fluid.
02-10-19, 08:53 PM | #25 |
Re: Underwater SV
Thanks for the encouragement and yes water might explain why it fired initially and then gave up....
04-10-19, 12:26 PM | #26 |
Re: Underwater SV
ok its running! Yes I had been a bit optimistic about there not being contamination in the tank - it was full of muck so had to clean pump, filter and interior. Now it doesnt sound to bad although the oil has gone a funny colour very quickly......
04-10-19, 12:51 PM | #27 |
Re: Underwater SV
Get some cheap engine oil and change it then run it for a while and change it again----several times until there is no trace of water or crud in the engine. Id run some fuel treatment/redex through the system as well to ensure the fuel is clean. Then Id start on the electrics---connecters apart and contact cleaner/WD 40 everywhere.
04-10-19, 01:51 PM | #28 |
Re: Underwater SV
Must feel pretty good to hear it running again
If you buy "Seafoam" engine cleaner, you can use it in the fuel AND the oil, so think I'd be chucking in a can of that (along with the multiple cheap oil changes) You'll find it on eBay.
2018 SV650AL8 2001 KTM 640 Duke2 2015 KTM 390 Duke |
04-10-19, 07:10 PM | #29 |
Re: Underwater SV
yes its good. Its had the first oil change and theres no codes showing so well pleased. Suzuki can build em! Now I can start on all the auxilliaries....
04-10-19, 07:45 PM | #30 |
Re: Underwater SV
Sounds a bit odd to talk of luck when you've just had to empty your bike of filthy water, but as "JaxintheUk" pointed out, it could well have been alot worse with the battery fitted, so I reckon luck was on your side, er, sort of
Thread Tools | |
Underwater bowling... | Specialone | Idle Banter | 15 | 16-09-13 03:47 PM |
underwater camera housing` | Jimmy2Feet | Idle Banter | 14 | 03-04-11 05:14 AM |
Underwater photography | tricky | Idle Banter | 1 | 05-09-06 05:47 PM |
