Idle Banter For non SV and non bike related chat (and the odd bit of humour - but if any post isn't suitable it'll get deleted real quick). There's also a "U" rating so please respect this. Newbies can also say "hello" here too. |
28-10-08, 06:20 PM | #1 |
Central Heating Problem
The radiator in my hallway is fffffffffreezing cold, the pipe leading from the floor to the radiator is hot as are the nuts and bolts connecting that pipe to the radiator. There`s no air in it cos I`ve tried bleeding it and the valve is set to no. 6 the highest. Has anyone any ideas what could be wrong and if there`s something I can do to fix it myself without having to call out an engineer/plumber type person?
Any help appreciated |
28-10-08, 06:26 PM | #2 |
Re: Central Heating Problem
Is it isolated at the other end?
28-10-08, 06:28 PM | #3 |
28-10-08, 06:29 PM | #4 |
Dodgy valve perhaps? Does it warm up on any other number?
28-10-08, 06:31 PM | #5 |
28-10-08, 06:32 PM | #6 |
Is the valve on the other side closed?
28-10-08, 06:35 PM | #7 |
28-10-08, 06:35 PM | #8 |
Light a fire under it.
Ill get my coat. No you have it.
28-10-08, 06:37 PM | #9 |
Do you have thermostatic radiator valves? (one with numbers on) Try putting that one on max & turning all your other rad valves down to 0 & see if that one comes on.
28-10-08, 06:38 PM | #10 |
Yep have thermostatic valves... will turn others down now
central heating woes............ | tj2 | Idle Banter | 8 | 17-11-08 03:27 PM |
Central Heating Boiler | Reckless Rat | Idle Banter | 11 | 02-01-08 11:20 PM |
central heating timer help needed | sarah | Idle Banter | 32 | 14-06-07 07:39 PM |
Can anyone help with a central heating problem? | Shinsei Jutsu | Idle Banter | 19 | 07-03-06 10:23 PM |
