Old 25-06-18, 05:42 PM   #1
Squiz
Squiz's Avatar
Default K1 Battery 99-02 & RR
In need of a new battery and i have read that YTX12-BS is a good choice but the bike in question was an 05 SV650.
Will this be suitable for a 2001 K1 model?
From site suggestions they recommend YT12A-BS which I believe is a shorter version of the above with some other spec differences.
Also, has anyone got a link to a MOSFET RR for a 2001 K1? struggling to find one.
Squiz is offline   Reply With Quote
Old 26-06-18, 11:51 PM   #2
kbh
Default Re: K1 Battery 99-02 & RR
Sorry can't help with the battery but this is the mosfet rr I purchased for my sk1 https://www.ebay.co.uk/itm/Suzuki-SV...sAAOSwlY1ZNu6Z
It was also cheaper than buying direct from m&p. It's made by electrosport
kbh is offline   Reply With Quote
Old 27-06-18, 05:43 AM   #3
Before you buy the RR check how many connections your RR has, some curvies have two, some have one
Mine had two, it's a later 02 curvy
Old 27-06-18, 06:41 AM   #4
Squiz
Squiz's Avatar
Yeah that’s the same one I have seen on eBay!
Thanks for the advice
Can a loose battery terminal prevent the battery from charging while being able to crank the engine? maxinc Bikes - Talk & Issues 5 22-07-11 02:59 PM
dead battery - possible reg/rec + battery? collis SV Talk, Tuning & Tweaking 8 20-09-10 02:47 PM
Optimate battery charger drains the battery flymo Bikes - Talk & Issues 10 10-06-09 10:41 AM
Battery/Starting problem - new battery hasnt fixed it! Aaron SV Talk, Tuning & Tweaking 13 24-01-05 05:21 PM
