01-03-12, 01:26 PM | #1 |
Thermostat removal?
After finding out my bike is running rich (only getting around 33mpg) i checked the coolant as recommended by the garage. thats sorted so on to the next thing on the list - the thermostat.
Basically i want to know: Is it easy to do i.e. get in and out? Is there any useful tips regarding the removing and putting back in of the air box and throttle body? |
01-03-12, 06:21 PM | #2 |
Re: Thermostat removal?
Not sure if this is normal either - not far from home noticed my temp on the speedo and it read 101 degrees. set off and within 200 yards it had dropped to 71 and i was only doing 30
03-03-12, 04:09 PM | #3 |
Can anyone help me on this one?
03-03-12, 04:34 PM | #4 |
What does it drop to when cruising?
They're a bit of a git to get at.
04-03-12, 01:24 PM | #5 |
Its in the 70's or 80's, but its drinking fuel big time. Did a dyno test and its running rich, someone else suggested the fan isn't coming on which might be right bit not sure how to check it
04-03-12, 01:47 PM | #6 |
what year is your bike?
04-03-12, 03:20 PM | #7 |
its an '03. trying to check everything possible, as the last resort is a power commander, which I can't afford.
04-03-12, 03:25 PM | #8 |
No fan at 101 degrees and that wouldn't make it use fuel.
How badly is it doing?
04-03-12, 03:49 PM | #9 |
its doing about 33 a gallon. much less than it should I reckon. doesn't even hit 100 miles before the petrol light comes on
04-03-12, 03:53 PM | #10 |
Sh*t the bed, that's a bit thirsty.
Is it running rich or misfiring? You looked at the plugs? Changed them? Dead rat in the airbox?
Thermostat Hose Union | squirrel_hunter | SV Talk, Tuning & Tweaking | 6 | 01-05-11 04:03 PM |
75 degree thermostat? | ronscotty | SV Talk, Tuning & Tweaking | 3 | 17-08-10 07:42 PM |
Thermostat Housing | cammy | SV Talk, Tuning & Tweaking | 4 | 24-04-09 09:29 PM |
Thermostat Switch Help | warrenhewitt10 | SV Talk, Tuning & Tweaking | 24 | 16-02-09 06:14 PM |
Chain buffer removal requires swing arm removal :-( | 2mths | SV Talk, Tuning & Tweaking | 1 | 09-07-07 09:19 AM |
