27-03-06, 01:45 PM | #1 |
Disabling 'parking' light switch
Hey,
I left my light on the 'parking' setting all weekend, and it's killed my battery. At £50 for a new one I don't want to do that again. Is it easy to cut a wire and disable that setting on the ignition? Yeah, I know it would be easier to just remember, but I'm not that clever. Cheers |
27-03-06, 02:29 PM | #2 |
The Sick Man
Could you not charge your battery?
Many of the new chargers will not charge batteries unless they can detect a small voltage and polarity. Optimate are designed to charge up batteries that have been deep discharged, or at least try to.
OTR: KTM 690 Duke R 2015 Full Akro SIDELINE: Kwak ZX636 A1P 2002, Red, R&G's, Yoshi, Double Bubble Screen GONE: Kwak ZX-7R P1, Full Akro, Undertray, Screen GONE: SV650S K2 Very Bruised & Without Fairing, Motovation Frame Sliders, R&G Ally Sprocket Toe Protector, HEL 2 Line Setup, GSXR K1 600 RWU Forks, Barnett Clutch & Springs, Penske 8981 Shock, Gilles Ti Rearsets, Steel Barends, Scottoiler, AFAM Chain & Sprockets, Twin FIAMM Horns, Skidmarx Bellypan, Full Micron Zeta Steel System, Cut down undertay. Forum Problems & Information / Site Suggestions |
27-03-06, 04:29 PM | #3 |
i emptied my battery this way, and managed to jump it and had no trouble since, was yours already on its way out?
27-03-06, 07:07 PM | #4 |
What bike have you got?
27-03-06, 07:42 PM | #5 |
just re charge it!-
I have done this TWICE ! and recharged both times.. I know once is a mistake twice is stupid <<<<<<<<<<<< stupid me
ooops I did it again ... new bike . cb1000r |
27-03-06, 07:44 PM | #6 |
27-03-06, 07:51 PM | #7 |
I'm paranoid about this, after leaving the lights on my old (1971) Beetle for 1/2 hour which drained the battery flat & it was being MOT'd the next day, grrrr! Charged it up & it started fine.
Even though this was about 10yrs ago, I'm still paranoid about leaving vehicle lights on. For the bike, I always have to switch it to parking, then switch it back one notch noting the lights going off.... |
27-03-06, 08:30 PM | #8 | |
Re: Disabling 'parking' light switch
27-03-06, 08:31 PM | #9 |
Pointy or curvy?
I don't have a diagram for a pointy, but on the curvy it is the brown wire from the ignition switch that drives the side lights. In the 'P' position, the ignition switch shorts the red wire (live feed) to the brown wire. In the ‘ON’ position it connects the Brown and Grey wire (Grey is then the +ve feed (from the lighting circuit)). It is these two (Brown and Grey) you want to snip and join before they enter the ignition switch to eliminate the ‘P’ circuit. If it is a pointy, I will need a pointy diagram, but wouldn’t be surprised if the colours are the same. The cleanest way to do this mod is to remove the two wires from the connector just before the ignition switch, then join/touch these and tape them to check the circuit. After that then you can join properly with solder/crimps/bullets or whatever. No more flat batteries!! Enjoy!! |
28-03-06, 09:21 AM | #10 | |
2 blown brakes light bulb's and a parking light. | Grinch | SV Talk, Tuning & Tweaking | 4 | 20-10-08 11:08 AM |
Headlights Only light up with passing switch | Binky800 | SV Talk, Tuning & Tweaking | 11 | 02-07-08 06:56 PM |
Brake light - switch? MOT req't? | Chipstix | SV Talk, Tuning & Tweaking | 8 | 03-07-07 09:34 PM |
Front brake light switch | svrash | Stuff Wanted | 0 | 21-03-07 11:01 AM |
Rear brake light switch | dirtydog | Stuff Wanted | 4 | 29-12-06 08:50 PM |
