25-07-07, 09:53 AM | #1 |
pops n'bangs galore
Ok, so I have a new exhaust on my bike which was sounding better for a week and seemed to be doing just fine, but this morning I was riding for an hour and when accelerating, all speeds and all gears, it started making popping noises.
I thought it may be warming up or perhaps the oil was low, but after an hour it was pretty hot and the oil level seemed to be fine. I'm not at all technical and don't have a clue what it could be! I've checked that the connections are ok and it seems fine but am lost for ideas as to what else may be causing it. Anyone had this problem and had it sorted ok? I'm nervous about taking it to a garage as funds are low and I hear they just rip you off. Bit negative I know! But probably also justified Also...should it be safe to ride around on without making the problem worse? I have a few things I really need to do...starting now! Ta |
25-07-07, 09:59 AM | #2 |
Re: pops n'bangs galore
the sv does pop and bang with a race can on but usually on the (throttle off after acceleration), if this is the case then its normal just enjoy
25-07-07, 10:44 AM | #3 |
I have a Viper race can, and mine does it all the time, so it should be doing what it is supposed to, i like it lol, normally happens in 3rd when i let of the throttle at about 38Mph gives out a nice POP and BANG lol, ! ! !
25-07-07, 11:00 AM | #4 |
cool avatar lylej.
25-07-07, 11:17 AM | #5 |
25-07-07, 11:25 AM | #6 |
Yeah mine pops when you shut the throttle, its all part of having an aftermarket can. Unless you mean the pops are coming from the engine rather than the exhaust?
25-07-07, 11:32 AM | #7 |
Ah yes, I quite enjoyed some of the other pops too The ones I'm concerned about are the accelerating pops, not the decelerating. It could be coming from the engine...I've tried listening but am really not sure where it's happening exactly! How can I tell?
25-07-07, 11:37 AM | #8 |
could have a loose seal or connection somewhere then, check your pipes to see if there is a gap.
25-07-07, 12:05 PM | #9 |
is it a curvy or pointy? if it is a curvy, take the carbs off, and on the front carb, there should be a short bit of hose coming off with a screw in the end. this is the block off for the vacuum on the front carb. the piping on mine was all cracked and split, that was causing mine to pop like crazy. fitted a new bit of hose, screwed the screw back in and now its smooth as ever. very rarely backfires while letting the throttle off.
25-07-07, 12:16 PM | #10 |
Cheers for advice
It's a pointy but I'll employ the help of one trusty 'cat' and have a look at taking it apart if it doesn't magically sort itself out before then... |
Pops | Endellion | Bikes - Talk & Issues | 2 | 26-05-07 08:10 AM |
Pops, bangs and all manner of funnyness??!!!! | Carrot Cruncher | SV Talk, Tuning & Tweaking | 0 | 09-08-06 11:40 AM |
Stalls and pops | Mark_h | SV Talk, Tuning & Tweaking | 3 | 25-08-05 04:47 PM |
