Ok, so I'm starting to get everything sorted out. I've replace the front rotor already and I have all my parts ordered. I am prepping the bike so when the parts get here I'll just have to put it all back together.
One problem though. How do I get the water pump out? I removed the 3 bolts holding it in place and carefully pulled it out but it only comes out about a half inch then stops. Any advice would be welcome. |
You need to remove the ain drive gear from the other side, I think. Which, if I recall correctly, means removing the whole side casing.
meaning I need to drain the oil too...
Can anyone else confirm this before I tear into it? |
If I remember, I'll check one of the casings in the garage, that'll tell me for sure- though most likely someone else can tell you for sure.
Knob faced knobster
Yeah you have to take off the engine casing to get the water pump off
2001 SV650 in shimmerin green, Not broken anymore |
#6 | |
205 pugi DTi water pump... | Richie | Idle Banter | 2 | 01-12-07 04:46 PM |
Water Pump....leak | 21QUEST | SV Talk, Tuning & Tweaking | 9 | 07-11-07 09:02 AM |
Removing the Water pump housing | Grinch | SV Talk, Tuning & Tweaking | 6 | 24-04-07 10:26 AM |
Water pump on VW Passat | rpwoodman | Idle Banter | 11 | 08-05-06 06:15 PM |
Water Pump Leak | greeno76 | SV Talk, Tuning & Tweaking | 2 | 24-04-05 04:56 PM |
