Old 19-04-21, 07:18 AM   #2201
admin
John T
admin's Avatar
Default Re: What have you tinkered with today?
This is why a lot of people don't bother. Mine was checked at 16k, it's now done 39k......
Old 19-04-21, 08:11 AM   #2202
Adam Ef
Adam Ef's Avatar
I'd say it's necessary to do it at least once early on. Then they probably don't change much with later miles. 0 to 16k probably causes the most wear on the edges of the valves. It's definitely good that I checked mine. I'm guessing it's never been done. I have three VTEC valves that are in spec and everything else it too tight. A couple of them very far out of spec too. That's 13 valves out of spec!
I've got a feeling that's why my fuel economy on this and the previous VFR isn't great. The last one got about 35mpg and this one isn't much higher. It'll be interesting to see if that gets better after the valves are done. It would make sense that valves not closing properly wastes fuel.
Past:
Old 19-04-21, 08:56 AM   #2203
admin
John T
admin's Avatar
I've always hated shim based valve systems. It wasn't so bad when the shims were on top of the buckets but having to take cams out to alter clearances is ridiculous.
Having said that neither of my two SV's ever needed adjustment in all the time I had them.
Old 19-04-21, 09:10 AM   #2204
CheGuevara
Not bike related, but a little while ago I built some oak Adirondack chairs (with pull-out leg rests) and I finished oiling them this weekend - in time to enjoy yesterday's sun (and a few cold beers).
- K9 SV650S: Hel brake lines, carbon end can
- SZR660: The project...
- K5 SV650S: K7 GSXR750 front end, ZX6RR shock, GB Moto rearsets, Hel brake lines, Renthal risers, Tuono bars, V-Rod headlamp, "JMV" belly pan ~SOLD~ (wonder where it is now)
CheGuevara is offline   Reply With Quote
Old 19-04-21, 10:40 AM   #2205
admin
John T
admin's Avatar
They look fab, nice job.
Old 19-04-21, 10:45 AM   #2206
lovely work, well done
wont the oil stain your clothes?
Old 19-04-21, 11:08 AM   #2207
CheGuevara
Thanks both - I'm not a woodwork guy so much, so I was quite pleased with the results. I've built templates -so may do a couple more in softwood (the oak was expensive).
Oil-wise I used 2 coats of Barrettine wood preserver followed by two coats of Osmo UV 420 - it dries to an almost varnish-like finish so should be OK on clothing, and hopefully keep them from silvering for a few years)
Old 19-04-21, 11:35 AM   #2208
Dave20046
Dave20046's Avatar
Oak is eyewatering! It'll last forever though. Looks really good.
Old 19-04-21, 04:45 PM   #2209
Chris_SVS
Chris_SVS's Avatar
Investigating poor fuel economy in the car, started with 4 spark plugs that looked like they were put in, at Nissan 60k ago...
Ended with an o2 sensor error which means cleaning both of them to rule out A) Bad sensors B)Cat converter needing replacing.
Bikes are easier!
Chris_SVS is offline   Reply With Quote
Old 20-04-21, 09:01 PM   #2210
redtrummy
Took Suzy for a MOT Monday - stripped down front brake today! Bike passed but pads not releasing cleanly. Waiting for a rebuild kit now.
redtrummy is offline   Reply With Quote
Been got already today.. 454697819 Idle Banter 16 01-04-10 02:08 PM
Today DaveP The Border Patrol 4 02-03-10 10:52 AM
Going out today? tj2 The Border Patrol 1 01-06-09 09:22 PM
Today Tara Guildford Massive 14 02-06-08 11:56 AM
Today...... Caddy2000 Idle Banter 15 19-04-06 05:39 PM
