24-03-07, 12:11 PM | #1 |
Power Commander
OK thoughts on these things please.
I have a high level Remus Can on my SV650 pointy K6. I am thinking of getting a K&N filter and removing the snorkel. This combination of changes is obviously going to cause the bike to run lean. If I get a power commander and put it on and run it on the base map willl that help? I can order a power commander from JB Racing and they will pre load a map on the commander if I give them my modifications. Question is: Is the second option any good, or am I as well taking the bike to dyno and getting a custom map. Which means a fair ride for me round here. Which is why I like option 2?? |
24-03-07, 12:23 PM | #2 |
Re: Power Commander
A custom map will aways be better, the power commander will be "ball park" probably over rich to air on the side of caution.
Cheers Mark.
24-03-07, 12:36 PM | #3 |
Re: Power Commander
How much does it cost to have a custom map set up on the power commander at a dyno centre????
24-03-07, 12:46 PM | #4 |
Re: Power Commander
Get them to use a yoshi box and put it on your ecu, better all round.
24-03-07, 01:06 PM | #5 |
Re: Power Commander
OK Mark, please enlighten me, whats a Yoshi Box?
24-03-07, 01:23 PM | #6 |
Re: Power Commander
OK, before I start,do you know how a Power commander works at all?
24-03-07, 01:31 PM | #7 |
Re: Power Commander
Actually, have a look at these first, then I'll answer any questions you have.
http://forums.sv650.org/showthread.p...hlight=tuneboy http://forums.sv650.org/showthread.p...hlight=tuneboy Cheers Mark.
24-03-07, 02:58 PM | #8 |
Re: Power Commander
Cheers that explains everything crystal clear.
Nest question is where from and how much?? |
24-03-07, 03:15 PM | #9 |
Re: Power Commander
PM SVRacer off here - she is with Steve Jordans and will prob look after your needs/qstns.
24-03-07, 05:52 PM | #10 |
Re: Power Commander
How much is a personalised map on a power commander at a dyno centre???
TRE/TPS/Power Commander?? | phil24_7 | SV Talk, Tuning & Tweaking | 3 | 11-02-07 04:47 PM |
Power Commander power graph print outs. | JimPSV | SV Talk, Tuning & Tweaking | 19 | 27-11-06 09:39 AM |
power commander | latts650s | For Sale - SV's and SV related items | 0 | 23-03-06 04:40 PM |
Power commander | latts650s | For Sale - SV's and SV related items | 3 | 23-02-06 09:35 AM |
should i buy a power commander ? | Warren | Idle Banter | 6 | 13-06-05 10:59 PM |
