09-06-16, 11:27 AM | #1 |
oil filter leak
I've made a bit of a mass on my last oil change. I'm pretty sure I've over tightened the oil filter and I've got a tiny leak.
Is there any way I can correct this without taking the filter off(loosen off slightly)? If not, I'll drop the oil and re-seat the filter and reuse the oil. Bike is a daytona 675 Ta! |
09-06-16, 12:36 PM | #2 |
Re: oil filter leak
the only time you can over tighten an oil filter is when you tighten that much you strip the threads then it goes loose.
you should always 'spin' and oil filter on. if there is any resistance till the filter gasket hits the mating face of the engine then you have x-threaded it. oil filters only need to be 'hand tight' then a half turn. always lightly oil the gasket of a new filter. always clean the mating face of the engine. always 'spin' a filter on. |
09-06-16, 12:50 PM | #3 |
Re: oil filter leak
I don't get it then... I don't remember any resistance when spinning the filter on, I did hand tight and then a bit - that's where I though the overtight came from. I've definitely didn't go that far to strip it.
I'll get a new filter and reuse the oil, once I have the fairings off, I can investigate further... I've never had an issue with this before either :/ Cheers! |
09-06-16, 01:37 PM | #4 |
Re: oil filter leak
The o ring on the filter might be creased or damaged. Id replace it just to be safe, they are relatively inexpensive, its just a faff to drop oil again etc.
09-06-16, 02:44 PM | #5 |
Re: oil filter leak
how bad is the oil drip?
09-06-16, 03:59 PM | #6 |
Re: oil filter leak
Nothing under the bike after 6h but this when looking from the front:
11-06-16, 11:19 PM | #7 |
Re: oil filter leak
are you sure its coming from the filter, could it be the sump plug seal?
Air Filter & Oil Filter from TL1000R fit SV650? | AkiraSV | SV Talk, Tuning & Tweaking | 3 | 04-08-11 05:19 PM |
Spark Plugs, oil filter, Air Filter....Curvy | 21QUEST | For Sale - SV's and SV related items | 2 | 14-01-10 10:04 PM |
Oil leak from filter | andyb | SV Talk, Tuning & Tweaking | 27 | 25-07-07 04:38 PM |
To filter or not to Filter.....are you feeling lucky? | Magoo | Bikes - Talk & Issues | 40 | 02-12-04 05:17 PM |
Not oil leak - Petrol leak - double "Bugger"...! | Potts | SV Talk, Tuning & Tweaking | 1 | 17-10-04 08:16 PM |
