05-07-19, 04:15 PM | #11 |
Re: Painting Exhaust - Silencer Can
05-07-19, 04:21 PM | #12 |
05-07-19, 07:25 PM | #13 | |
05-07-19, 07:30 PM | #14 | |
05-07-19, 08:01 PM | #15 |
05-07-19, 08:04 PM | #16 |
I've used Halford's VHT.It's decent paint
"Stultus est sicut stultus facit" Last edited by R1ffR4ff; 05-07-19 at 08:05 PM. |
05-07-19, 08:34 PM | #17 |
07-07-19, 08:05 PM | #18 |
Have used Simoniz very high temperature paint on all the pipes and CAT under my AL7 because I thought it looked better with the pipes blended into frame colour rather than shiny and standing out. Also painted the silver heat shield on the black silencer because that offended my eyes ( although heat shield does not get hot ). The paint has stood up well, it is a satin finish at her than gloss, and is guaranteed up to 800C and is specified for manifolds and exhausts..
08-07-19, 09:17 AM | #19 | |
However my other problem is curing it; as I mentioned in opening messages I have bought the exhaust over eBay and it’s not fitted, so wanted to paint before fitting, but then how will I cure? So thinking to use heat gun and blow the hot air through, or chop the original exhaust, loose fit this one, remove, paint and do the final fitting. Last edited by Thaleshwar; 08-07-19 at 09:18 AM. |
08-07-19, 09:33 AM | #20 | |
What I do when doing off bike bits is this.Fully prep and clean the part.Attach some wire or similar system so you don't have to pick the part up with your hands or if you can't do that a pair of Marigold type Kitchen gloves to prevent fingermarks on the job. If possible have a warm room ready where you can hang/leave the painted job. Warm the part up with a Hairdryer and whilst doing that leave the Rattle can in a large pan of warm to hot water and keep agitating the Can to the heat gets to all the paint in the can. Then just prior to spraying use a Tac-Rag https://www.toolstation.com/prodec-t...SABEgLZyvD_BwE Don't try and cover in one coat.Use a light Dust/Grip coat all over the job and leave for 5 mins.Then a better heavier coat but again not too heavy and leave for 5 mins and then a final coat. If you can't bring the part into the house but have a garage or somewhere you can hang it up and use the Hairdryer again but only in short bursts from a distance.The solvents in the paint need to,"Flash-off".The longer you can leave the part in the warm to naturally cure the better.
Fuel Exhaust silencer. Pointy. | YannG | For Sale - SV's and SV related items | 14 | 27-09-14 08:30 AM |
Suzuki SV650 S 03-10 Standard Silencer Exhaust End Can | ian505050 | For Sale - SV's and SV related items | 0 | 05-02-12 06:23 PM |
Removing the Silencer/muffler of a scorpion exhaust. | musne | SV Talk, Tuning & Tweaking | 8 | 17-01-12 07:22 PM |
Free Standard Sv 'Bazooka' Exhaust Silencer | cluffy | For Sale - SV's and SV related items | 4 | 26-03-11 11:43 AM |
Pointy Exhaust For Sale. (All minus silencer) | thefallenangel | For Sale - SV's and SV related items | 0 | 30-01-09 11:35 PM |
