Old 12-05-17, 01:14 PM   #1
dyzio
dyzio's Avatar
Default White rust/corrosion
Hi all,
Does anyone know what this white stuff actually is and is it possible to get rid of it? I mean the white stuff on the engine casing and the rear shock.
Cheers,
Old 12-05-17, 02:04 PM   #2
macamxthe1st
Default Re: White rust/corrosion
I hope that I am wrong but it looks to me like damage to the laquer on the engine casing due to "salt" and worse is I think that it is virtually impossible to get shot of without removal of the laquer, polish and reapply. Sorry to be so negative but I have come across it many times and it is a real bugger.
Geoff.
I really hope that I am wrong on this and someone else knows better.
Old 12-05-17, 02:15 PM   #3
SV650rules
Do you ride when salt on the roads ? This is probably magnesium / aluminium alloy corrosion (magnesium and aluminium oxide). Clear coating has got damaged and water / salt moved in to cause galvanic corrosion
You can use ACF-50 throughout winter to keep water and salt off your bike parts. It will get to look dirty and tatty, but once you clean it off the aluminium will be in much better shape.
2016 SV650 AL7
Old 12-05-17, 02:35 PM   #4
dyzio
dyzio's Avatar
The picture is of a bike I might be looking at with a friend.
It's a 500cc Honda, 10years and wait for it... 5000 miles on the clock. The picture is the best one showing the problems, thought the paint might be damaged just thought to ask as well.
Old 12-05-17, 03:53 PM   #5
Stilo
Stilo's Avatar
Can't see the shock but itis definitley corrosion on the engine casing. My Ducati was the same when I bought it (they are known for it). Plenty of elbow grease & assorted abrasive papers will remove it, apply a good etch primer, engine silver & then clear coat (all available in rattle cans & on Ebay)
He was a hairy handed Gent who ran amok in Kent Awhooo
Stilo is offline   Reply With Quote
Old 13-05-17, 11:56 AM   #6
R1ffR4ff
R1ffR4ff's Avatar
If you want a cheap way of tarting it up I did this engine with Plastikote Satin Radiator paint.I'm a Paint sprayer by trade and can tell you this stuff is amazing;
http://www.ebay.co.uk/itm/Plasti-kot...IAAOSw-vlVm6yR
And Rustoleum do a version as well.
http://www.homebase.co.uk/en/homebas...--400ml-682383
I did several of my CX500 engines with it,
No primer required.Drys really quick to a nice satin finish so no clear-coat required.
When the paint becomes tired touching up is easy.Quick scuff down and spray and it blends so well you can't see the touch-up.
As it's Radiator paint it can handle the engine temps no problem.
HTH
Tip:
Whilst you prepping the job stand your aerosol can/s in a pan or bowl of warm water.Will help with application and speed up drying.
If you do ever use a primer you can use a Hairdryer to heat the primer after application to speed up the job and the same with the top-coat/finish
I'm actually doing a bit of touch-up on my SV as I type
Old 13-05-17, 09:17 PM   #7
Blapper
Blapper's Avatar
The alternator covers on my old Beemer twins used to get stained by salt (dark stains because it is a better alloy than Jap crap alloy is) so I used to spray them with a light dusting of UHT silver paint. They looked like new, washed off easily and never stained again.
Old 29-05-17, 07:57 AM   #8
SV650rules
http://www.cbxclub.com/davespage/mcy84-1.html
This is interesting read, pure aluminium is very resistant to corrosion but its strength is crap, when you start to alloy it to get better strength (with silica and magnesium etc.) then corrosion becomes a problem. Some cleaners / degreasers are too aggressive and the chemicals they contain can get into pores of aluminium and cause corrosion even when you think you have rinsed them off pretty well. Some cleaners are so aggressive they even attack clearcoat.
2016 SV650 AL7
SV650 Corrosion/Rust removal? isutty5 SV Talk, Tuning & Tweaking 12 21-03-15 08:09 PM
Need a White Rear Hugger White 2012 SL2 eeewee69 SV Talk, Tuning & Tweaking 2 16-10-12 05:01 PM
Corrosion on K7. daveb SV Talk, Tuning & Tweaking 2 06-03-09 04:19 PM
Rust & Corrosion advice Foxy Bikes - Talk & Issues 35 03-06-08 08:37 PM
