01-09-08, 09:18 PM | #1 |
Sump plug bolt
sump plug bolt has rounded!
took the oppurtunity to do an oil and filter change on sunday as the rain had stopped. When i tried to undo the sump plug bolt the socket went round but the bolt didnt Dunno why this has happened as i did it up last time to the right torque, unless my torque wrench is knackered too. My problem is how to get the bolt out, and where can i get a new one from? does it have to be from suzuki? |
01-09-08, 09:21 PM | #2 |
Re: Sump plug bolt
why on earth would you want to do it up with a torque wrench?
getting it out may be tricky can you get molegrips on it? should be cheap enough for a new one |
01-09-08, 09:25 PM | #3 |
Re: Sump plug bolt
I would guess it's a suzuki one, it's fine pitch IIRC
Don't do it up so tight next time. Mole grips, or carefully weld something to the bolt to get it off.
01-09-08, 09:28 PM | #4 |
Re: Sump plug bolt
01-09-08, 09:36 PM | #5 |
Re: Sump plug bolt
Not unless they make magnetic ally
01-09-08, 09:46 PM | #6 |
Re: Sump plug bolt
Getting a new one wont be all that dear or hard 2 get your only problem is geting your old one out now.as said above dont tighten it as much the next time! and 2 try and get this one out either go the next socket down and hammer it on if its not rounded enough for that then either weld something 2 it or try mole grips.
01-09-08, 09:48 PM | #7 |
Re: Sump plug bolt
01-09-08, 09:49 PM | #8 |
Re: Sump plug bolt
OK then that's worth checking before you put MIG gun on it
01-09-08, 09:52 PM | #9 |
Re: Sump plug bolt
Also whatever you do dont strip the thread in the (alloy) crankcase as that gets expensive to sort out.
01-09-08, 09:53 PM | #10 |
Re: Sump plug bolt
might be differant on the sv?
is it a steel bolt into alloy casing? |
Sump plug washer - where from? | pencil shavings | SV Talk, Tuning & Tweaking | 26 | 17-03-09 08:52 PM |
how to get the sump plug/bolt or filter bolt out without murdering someone? | Paul the 6th | Bikes - Talk & Issues | 11 | 31-05-08 10:49 AM |
Sump Plug Torque? | skov | SV Talk, Tuning & Tweaking | 2 | 27-02-08 08:38 PM |
Drilling Out Sump Plug? | UlsterSV | SV Talk, Tuning & Tweaking | 13 | 15-04-06 05:22 PM |
Pants! Sump plug... | localhost | Bikes - Talk & Issues | 12 | 20-01-06 11:27 AM |
