26-05-19, 05:40 PM | #1 |
Junior Member
ASV Clutch & brake levers
Has anyone got any experience with ASV aftermarket levers?
I've got a curvy with cheap chinese aftermarket stubby levers, but the bike came with the original levers in a box. I'm currently deciding whether to put the originals back on or shell out for a hopefully better set of aftermarket ones. All comments and opinions gratefully received. |
26-05-19, 07:03 PM | #2 | |
Re: ASV Clutch & brake levers
In my humble opinion: the standard levers are just fine, the bike is best the way the designer intended it. Sent from my iPad using Tapatalk |
26-05-19, 08:19 PM | #3 |
I have a set of the Chinese dogleg levers on mine. I find them more comfortable and easier to adjust with gloved hands than the originals. My only complaint about them would be that the pivot hole on the clutch lever ought to be bushed. I've just replaced my first pair of them with another identical set after 7 or 8 years as the hole had elongated. I'm intending to buy a another pair and fit a bush to the pivot hole.
**EDIT** just to add that mine are the full length dogleg levers, not the short ones. Last edited by garynortheast; 26-05-19 at 09:28 PM. |
26-05-19, 09:12 PM | #4 |
Not the ASV, but I bought my bike with two identical (I thought) black shorty adjustable levers. Brake lever is a Pazzo, so I assumed clutch was as it looked the same. A few years later the clutch lever is a silvery grey colour, no longer black. Looks like it's a cheap copy. Has a bit of play in it now too, but a washer seems to sort that out. The genuine Pazzo is still black and solid.
I've always found the clutch lever fairly heavy, even after I fitted a new cable which I though would fix it. Possibly as the levers are short?
>>> ? <<< Past: Street Triple 765rs, DRZ400s,GSXR1000 K9, VFR800 A8, ZX6R 636 2006, CRF250L, GSXR750 K7, VFR800 A7, GSXR750 L3, Street Triple 675R, MT09 Tracer, SV650s K8, CB250rsd, YBR125... |
27-05-19, 07:01 AM | #5 |
Here's a search result from this forum on ASV levers, hopefully it will have some useful info:
https://tinyurl.com/y5hdg985 |
Brake and Clutch Levers | nikon70 | Stuff Wanted | 0 | 13-02-14 07:28 AM |
Clutch and brake levers | Bicastf | Hardware | 11 | 17-09-12 05:31 PM |
Adj Clutch Brake levers? | edmc | SV Talk, Tuning & Tweaking | 2 | 24-01-11 11:14 PM |
Curvy Carbs, clutch levers and brake levers | 21QUEST | For Sale - SV's and SV related items | 2 | 03-03-10 11:04 AM |
Brake/Clutch Levers | Tris | SV Talk, Tuning & Tweaking | 1 | 18-06-07 12:58 PM |
