Old 25-02-19, 03:55 PM   #31
Othen
Default Re: Removing Exhaust Bolts
Originally Posted by shiftin_gear98 View Post
Bodge it and ride it.
If it leaks find lots of tunnels to ride through.
See if you are worried about it or something worse when the MOT is looming.
Oil all over the rear tyre is bad, a slightly blowing exhaust on a £600 pony. Up to you.
Old 25-02-19, 04:40 PM   #32
Glad you got the bolts out! I had one snap years ago. Not fun
Is your oil cooler bent forward, or am I imagining that?
Old 25-02-19, 05:06 PM   #33
Adam Ef
Adam Ef's Avatar
To be honest, in the middle of my 2 weeks of dealing with my sheared bolt I put it all back together with only one bolt holding it in place and the old gasket left in so I could ride it around to people to see if they could help... and it all worked fine. The bracket was on at an angle with only one bolt holding it, but nothing seemed to be leaking and it ran perfectly. I did the gasket as I'd ordered one, had the dremel with attachments to make it easy to cut out the old one and sand back the corrosion and wanted to just do it all properly as I had it apart. I didn't want to be doing it all again any time soon. Although I will exercise those bolts and maybe remove and regrease them from time to time to make sure they never seize again.
If it was me I'd get the gasket out and a new one in, but you may well be fine without. It was the easiset part of my ordeal.
Old 25-02-19, 05:34 PM   #34
Othen
The oil cooler: I was thinking maybe it leans back a bit - it all seems to be properly attached by the two bolts at the top, but I think the new oil pipes are thicker and stiffer than the Suzuki ones. I think that might push the bottom forward a bit? I'll park in on the flat, on the paddock stand some time and check.
Alan
Old 25-02-19, 05:39 PM   #35
Othen
Thank you for that - I have a feeling it will run perfectly well with the old seal in place and what you have said rather confirms my suspicion. I don't have a Dremmel (I suppose it would be an excuse to acquire one), also I'm just a little bit loath to take any more risks. I've ordered the new seals, so if I have any problems I could probably take the header off in minutes to get them fitted. I'm sort of talking myself into using the old seals.
Like you I was going to crack each of the Allen bolts once a year, and maybe put a smear of copper brake grease on the threads when I put it back together.
Alan
Old 25-02-19, 06:21 PM   #36
The seals are pretty soft and shouldn't be too difficult to remove, even if it's been in there for a while. I just got a thin screwdriver behind it, when I changed mine, a few light taps and a twist and it deformed and then it came out
Old 26-02-19, 10:45 AM   #37
Othen
The new seals and SS Allen bolts both came in the mail today, so I'll fit the seals before buttoning up the whole thing this afternoon.
Many thanks,
Alan
Old 26-02-19, 05:36 PM   #38
Othen
All done, the new seals and bolts both came in the mail today and the bike is back together:
No leaks and it sounds fine.
I did change the seal, but I was sort of wishing I hadn't bothered half way through, it was hard to get the old one out and lots of cleaning up was required:
... the old one is at the top!
End of this thread I think, many thanks for your contributions.
Alan
Old 28-02-19, 09:36 AM   #39
Othen
... to round off this thread:
That is all the work I'd intended to do on this project bike, it now stops, starts, runs, keeps the water and oil inside the engine and the exhaust gas inside the muffler. I'll tax if from 1 April and enjoy it for a while. I think it came out quite well for a £900 bike:
Old 28-02-19, 10:17 AM   #40
shiftin_gear98
shiftin_gear98's Avatar
Of course it did, it's a Pointy.
Removing Rounded Allen Bolts L3nny SV Talk, Tuning & Tweaking 20 14-11-16 04:40 PM
removing front header bolts today.... DomP SV Talk, Tuning & Tweaking 13 22-02-16 09:01 PM
Removing engine bolts. andrewsmith SV Talk, Tuning & Tweaking 8 02-01-11 08:56 PM
removing exhaust bolts barwel1992 SV Talk, Tuning & Tweaking 53 19-12-10 11:21 PM
Removing bolts pben47 SV Talk, Tuning & Tweaking 13 30-07-08 04:16 PM
