14-05-12, 08:27 PM | #1 |
Misfiring in the Rain.
'Evening all,
I have the dreaded misfire-in-the-rain problem. Its like riding a bucking bronco, but without the fun bit. I've checked the drain hole, and it seems clear. Sprayed a bit of WD40 in for good measure... Should I also be removing, silicone greasing, and replacing the spark plug too? Do I need a Fender Extender?! Cheers James. |
14-05-12, 08:29 PM | #2 |
Re: Misfiring in the Rain.
I'd at least try drying the hole and throwing some grease in there.
14-05-12, 08:30 PM | #3 |
Drying the drain hole? With pipe cleaners I guess?
14-05-12, 08:48 PM | #4 |
I would replace your front plug, i had the same problem a while back. Changed it over, sprayed a bit of wd-40 on it for some water resistance and she ran perfect.
14-05-12, 08:59 PM | #5 |
Yes, don't worry about replacing the spark plug, just some silicon grease where the rubber gromment seals the plug lead at the cam cover
Curvy misfiring in the rain. | hm-89 | SV Talk, Tuning & Tweaking | 11 | 12-04-12 10:22 PM |
Rain Rain, Go Away... the backup plan! | Ping | 2007 Annual Rideout | 39 | 29-06-07 09:31 AM |
Misfiring even in the dry! | thumper21 | SV Talk, Tuning & Tweaking | 9 | 04-03-07 06:14 PM |
Odd misfiring problem | drumwrecker | SV Talk, Tuning & Tweaking | 8 | 31-01-06 05:15 PM |
Misfiring | brolong22 | SV Talk, Tuning & Tweaking | 1 | 01-11-04 11:08 PM |
