09-12-20, 09:17 AM | #1 |
New battery
Time for a new battery. The Numax gel battery I fitted about 6 years ago is starting to give up. To be honest I didn’t expect it to last this long as it only cost around £30 back then. It’s given good service for a budget gel battery so I’ve ordered another one and was pleased to see it’s still only £32 delivered.
https://www.ebay.co.uk/itm/251229162366 |
09-12-20, 10:25 AM | #2 |
Re: New battery
I might give one of those a try soon, the GSXR doesn't seem to like the cold at the moment.
Currently driving a Corsa.... |
09-12-20, 12:03 PM | #3 | |
Re: New battery
I've also been testing a cheap under £10 R/R. Made webpage for it/them, https://cx500.000webhostapp.com/Mosf...orcycleRR.html They do a 12 amp Battery version as well for a bit more capacity. HTH
"Stultus est sicut stultus facit" Last edited by R1ffR4ff; 09-12-20 at 02:36 PM. |
09-12-20, 04:40 PM | #4 |
Re: New battery
Is it right that you need a different charger if you use a gel battery?
>>> ? <<< Past: Street Triple 765rs, DRZ400s,GSXR1000 K9, VFR800 A8, ZX6R 636 2006, CRF250L, GSXR750 K7, VFR800 A7, GSXR750 L3, Street Triple 675R, MT09 Tracer, SV650s K8, CB250rsd, YBR125... |
09-12-20, 04:43 PM | #5 | |
John T
Re: New battery
09-12-20, 09:45 PM | #6 |
Re: New battery
Like John, I don’t think so. I have used my Accumate charger on a couple of rare occasions with the gel battery and it doesn’t seem to have done it any harm. It’s hardly ever needed to be charged though, it seems to hold its charge very well even when not used for two or three weeks.
09-12-20, 11:36 PM | #7 |
Re: New battery
As above re. charger.
Cheers for posting Gary. I'm done with Varta and Yuasa are a bit pricier but still get nailed if the charger gets knocked off . I've been considering going cheaper.
10-12-20, 10:22 AM | #8 |
Re: New battery
Standard Motorcycle,"Step" maintenance chargers are fine for Gel batteries. It's the older constant current chargers that could cause a problem as they don't sense the Battery's internal resistance. They could still be used but the voltage across the battery would have to be constantly monitored so the charger can be removed when the battery has reached it's full potential.
I have an Optimate step charger in my garage for my SV but earlier this year I wanted a more powerful charger for some 12v car batteries I keep for projects and the Step charger's take over 3 days to charge these heavy duty Batteries. I found some new style chargers on eBay that are,"Dual Charge" and in default mode can supply much larger currents safely but also adapt and can be used on Motorcycle Gel batteries but are safer for Motorcycle batteries in their 2nd mode as it's a pulse/maintenance mode. Absolute bargain! £12.99 https://www.ebay.co.uk/itm/Smart-Car...4AAOSwtCxfECHc They are a little noisy as they have a small cooling fan but they charge so fast it's not an issue if being used on a big battery or out of earshot. Tanya do a 12amp version battery for SVs, £32.39 https://www.ebay.co.uk/itm/Powerline...MAAOSweiZfyfeP
"Stultus est sicut stultus facit" Last edited by R1ffR4ff; 10-12-20 at 10:37 AM. |
10-12-20, 11:37 AM | #9 | |
Re: New battery
10-12-20, 11:42 AM | #10 |
Re: New battery
Aren't all batteries fitted to new bikes nowadays the gel type ? I have mine on an Optimate if it is standing unused in the garage for more than a few days (which it is now ) I thought the old type that you topped up with distilled water went out of fashion a while ago now and the only other type was the lithium battery !
Thread Tools | |
Can a loose battery terminal prevent the battery from charging while being able to crank the engine? | maxinc | Bikes - Talk & Issues | 5 | 22-07-11 02:59 PM |
dead battery - possible reg/rec + battery? | collis | SV Talk, Tuning & Tweaking | 8 | 20-09-10 02:47 PM |
Optimate battery charger drains the battery | flymo | Bikes - Talk & Issues | 10 | 10-06-09 10:41 AM |
Battery/Starting problem - new battery hasnt fixed it! | Aaron | SV Talk, Tuning & Tweaking | 13 | 24-01-05 05:21 PM |
