26-05-08, 01:12 PM | #11 |
Re: Front Forks and Brakes on '00 SV650S
I am looking for the easier and cheaper solution so I think the full front end from SRAD is the better way to do it, right??
Why use TL1000S clip-ons and not any aftermarket set? From the SRAD I will need the forks, the triple clump, front wheel and front brakes system, right? Plus the TWF Bearing and a set of clipons and I am good to go? The ZX10 rear shock seems lot of trouble to fit, I think that ZX6 is plug and play solution... |
26-05-08, 01:13 PM | #12 | |
Pointy Ohlins on ebay |
26-05-08, 01:20 PM | #13 |
TLS clipons as they are higher than the 750 SRAD ones, brings the controls to the same lever as they are with a standard SV. You can use aftermarket ones but I would recomend getting high ones as some people have had clearence issues!
SRAD TL1000S |
26-05-08, 01:29 PM | #14 |
Yeah, you definately get what you pay for there's no question about that. I just can't justify that much money on it.
As for the swap you need a mudguard too. Also a front wheel spindle. The parts from the busas, TLS TLR, SRAD 600 and 750's are widely interchangeable. You also need some way to sort the speedo.
26-05-08, 01:36 PM | #15 |
Speedo can be rigged to the rear wheel easily, or go down the current mod of magnets and pick up. As for the brake system you will only need to calipers as the master cylinders are the same and the SV brake lines are longer so they will reach (good time to upgrade to braided lines if you haven't already). If you shop right you can get all your money back from selling the SV front end.
26-05-08, 01:38 PM | #16 |
You'll need the SRAD/TLS/TLR/busa discs too.
26-05-08, 02:52 PM | #17 |
26-05-08, 09:43 PM | #18 | |
The shock I am talking about has this bottle attached with a wire and you can mount it elsewhere.... |
27-05-08, 07:08 AM | #19 |
Yeah it's conveniently got remote reservoir, but is it any good?
27-05-08, 12:46 PM | #20 | |
Jambo
Modern motorcycles are bloody brilliant, enjoy it while we can |
Front brakes | DANINPLYMOUTH | SV Talk, Tuning & Tweaking | 0 | 17-04-09 11:08 AM |
Forks and brakes 99 | r4ce_e3nd | For Sale - SV's and SV related items | 7 | 31-05-07 11:31 AM |
Front Brakes | Tomcat | SV Talk, Tuning & Tweaking | 8 | 29-09-06 11:50 AM |
SV650s 2002 Front Forks (pair) | Madtone | Stuff Wanted | 1 | 18-01-06 01:19 PM |
front brakes | goldengraemes | SV Talk, Tuning & Tweaking | 1 | 24-01-05 09:07 PM |
