Old 17-12-05, 11:00 PM   #1
svrash
Default I give in...................help
My dilemma is this
The drain pipe that goes from the left side of the fuel tank (under the filler cap), through the inside and out the back to let over flowed fuel and settled water drain out the back has broken off at the top (under the filler cap)
I've so far tried Epoxy resin, araldite, JB steel weld and petro putty. I've also asked about welding it, but its to awkward a task to do and keep it neat and working
I'm now exhausted of ideas and need some input
Old 17-12-05, 11:49 PM   #2
Carsick
this isn't a suggestoin, just an observation. This seems to be happening quite alot.
Is this a common problem on bikes in general or just the SV?
Old 18-12-05, 08:08 AM   #3
svrash
not sure but it is rust related
Old 18-12-05, 12:03 PM   #4
Not quite, it's blockage related.
If the tube gets blocked it will fill with rainwater, then it'll rust.
Repairs aren't really practical, if you've tried to stick it back and had no success it's time for a replacement tank, it might be possible to have welded, but I wouldn't try.
Old 18-12-05, 02:09 PM   #5
andy owen
Tanks can be welded but have to be cleaned and then a tube from an argon bottle placed in the tank to purge the explosive fumes out ,and kept in place whilst welding. there are lots of firms out there that wil do the job for you.
Old 18-12-05, 02:31 PM   #6
The reason I wouldn't even try is that the tank drain can't be welded from the outside. The first tank I saw like this I took to a pro, (I do a bit of welding but I couldn't see an easy way to do this job), and simply it would cost more than a replacement tank as yours would have to be cut on the underside to allow access, and patched afterward, that plus the cost of the paint which may well be damaged.
It's not about being it being a fuel tank and the presence of fuel residue or fumes, it's simply about access and the consequent cost
Should I just give up? Caddy2000 Idle Banter 16 24-03-09 08:25 PM
I give in bris SV Talk, Tuning & Tweaking 25 23-09-08 07:10 AM
I'd give up now! DanDare Idle Banter 5 16-01-06 11:06 PM
For all those that don't give the nod The Mass Bikes - Talk & Issues 22 18-08-05 07:17 AM
