30-01-11, 12:48 PM | #1 |
K3 Engine Fix -Clutch basket removal & tools
So ... following on from my other threads i thought i would seperate this one with some pics & how a first timer did this...
Here is the tool i made and used Parts from b&q Bolts around 3 quid Flat bar around 7 quid btw if your look for a big torque wrench i had this for 20 quid out of argos! Silverline 27mm socket around 4 quid off ebay Sorted! ... tie wrap through middle holding all the bits in the right sequence for refit later. Here's how it looks so far ... Rotor next ...
Learn to maintain your bike, take it apart, rebuild the engine & more (using better bolts ), drop it & fix it again! K3 Job c.v: Engine:remove/split/rebuild/refit. Replace:Gearbox,Fuel pump,Gaskets. Piston clean,rings. Overhaul:Throttle body,Injectors,Brakes,Forks. Remove/refit:Exhaust,Radiator,Oil cooler,Throttle,Air filter,Tank. Replace: Oil,Coolant,grease,brake hoses & bleed. |
30-01-11, 02:11 PM | #2 |
Re: K3 Engine Fix -Clutch basket removal & tools
Despite your success do not repeat that method, the bosses on to which the clutch springs fix are too weak to allow this method to be reliable. I have previously seen it employed* and the centre nut at full torque will remain fixed in place while the clutch centre bosses snap off.
* More then once, and you are the first to demonstate it working without breaking something - I strongly advise against trying it twice.
30-01-11, 05:25 PM | #3 | |
30-01-11, 11:04 PM | #4 |
the easyest way to get the nut undone is with a half inch impact either air or a 18volt,it will also work on gear box sprockets as well and no need to jam any thing up to undo it, just hold the sprocket or clutch drum with a bit of rag and undo it and the same when doing them up
31-01-11, 09:31 AM | #5 |
I like to do all that stuff with the engine still fitted, easy then, just put it in gear
31-01-11, 09:09 PM | #6 |
engine split bud, knackered selector forks/gears - no choice although now i know how to change a clutch! - that's one thing about repairing the engine ive learned a lot of stuff along the way that most people put it in a garage for a pro to do!
Clutch basket options? | beabert | SV Talk, Tuning & Tweaking | 21 | 06-10-18 10:30 PM |
Clutch basket, calipers | Neeja | For Sale - SV's and SV related items | 0 | 20-09-10 07:58 PM |
Curvy Clutch basket | Grinch | Stuff Wanted | 5 | 30-09-08 02:02 PM |
Curvy Engine and Swingarm Removal Tools/Sockets | Demonz | Stuff Wanted | 11 | 21-07-08 03:48 PM |
