06-08-05, 10:51 AM | #1 |
Rear Brake Pedal Removal???
Hi Guys,
I need to change my Rear Brake pedal on my SV650S K5 but cannot see how to undo the bolt that holds the footpeg holder on? I thought it would be a allen key but I cant really see it very well so any ideas before I take a pair of grips to the bolt!!!! I await your words of advice! cheers |
06-08-05, 12:07 PM | #2 |
It is an allen key, but not one you'll find in the SV toolkit. You'll have to get one.
06-08-05, 05:26 PM | #3 |
yep, for all of those who dont know ....
It's an 8mm Allen Key !!!!! oooooooooo aaahhhhhhhhhh |
07-08-05, 04:25 PM | #4 |
Rear brake pedal??? K5 you say??? did ya grind it off on a roundabout??
or something a little...erm..."less stylish" ? Heh heh. |
07-08-05, 04:27 PM | #5 |
oooo goody i needed to ask this question mine broke when i came off on a roundabout. so it an 8mm allen key is it easy to do
12-08-05, 02:02 PM | #6 |
Yup...undo the 2(?) bolts holding on the entire plate, turni it slightly until you can get an allen bit and spanner/ratchet +bit holder onto the bolt...loosen,replace...tighten...reassemble!
Do people still use allen keys? |
12-08-05, 02:15 PM | #7 |
don't forget that you'll need a pair of needle nose pliers to bend the split pin on the rod connecting to the master cylinder.
99-02 rear brake pedal | Marcus | Stuff Wanted | 17 | 14-04-09 07:27 PM |
rear brake pedal? | seano | Stuff Wanted | 0 | 12-04-07 07:29 PM |
Rear Brake Pedal | 01 sv650s | Stuff Wanted | 1 | 29-03-07 10:11 PM |
Rear Brake Pedal | 01 sv650s | Stuff Wanted | 0 | 29-03-07 07:59 PM |
Rear Brake Pedal | teknovision2 | Stuff Wanted | 1 | 24-07-06 06:21 PM |
