Old 25-10-19, 11:43 AM   #11
embee
embee's Avatar
Default Re: Random Main dealer estimate!
The only caveat I'd offer is that carb balance is really the last step in the chain. All other things need to be correct first, for example valve clearances.
Before doing anything else, check that the choke plungers are free and not corroded, the cables are in good condition, and the chokes are shutting off completely when the lever is closed.
I'd suggest at least drain the float bowls to ensure there is no residual water sitting in the bottom (there very often is a droplet of water in there). There are drain screws fitted to do this, no need to dismantle.
Balancing the carbs by pressure gets the airflow essentially the same (all other things being correct), you'll then need to adjust the idle mixture screws to get the mixtures correct.
Old 26-10-19, 08:10 PM   #12
punyXpress
punyXpress's Avatar
How about Steve Jordan at Bookham near Dorking. ?
Probably not cheap, but used to do a bit with Supertwins and a bit far away - nowt better than a ready-warmed engine at this time of year!
Now: Street Triple R
Old 04-11-19, 05:45 PM   #13
gadget
Yeah, a bit of a trek really. I think I've found a local firm very near me through a couple of recommendations, got it booked in for a session with vacuum gauges so hoping it's going to be a straight forward balance. Will post my findings when it's sorted.
Cheers all for your input and suggestions.
gadget is offline   Reply With Quote
cage main dealer charges :( kwak zzr Idle Banter 19 30-03-11 06:05 PM
Would a main dealer stealer use manufacturers branded spark plugs? -Ralph- Idle Banter 34 14-02-11 10:43 AM
absoultely random stupid question - how far can you push a dealer? Paul the 6th Bikes - Talk & Issues 50 29-10-10 08:33 PM
RE; Main Dealer Experience (Honda) DSGMATT Bikes - Talk & Issues 12 23-09-09 03:00 PM
Main dealer servicing & warranty svrob SV Talk, Tuning & Tweaking 20 18-07-07 04:08 PM
