Old 22-07-06, 08:10 AM   #1
markward
Default numb bits
Hi ive just got a sv650s k6 and did a 300 mile trip yesterday and found my right hand went numb accross the palm (from holding my self up) does any one else suffer and did different grips or better gloves help as its ruining the "sv" experience, cheers mark
Old 22-07-06, 08:16 AM   #2
John Burt
Try adjusting your levers to bring them in line with your wrist, that is you normaslly have to move them down.
Old 22-07-06, 08:29 AM   #3
fizzwheel
fizzwheel's Avatar
Also try relaxing your grip on the bars and not hanging on for dear life quite so much Seriously it makes a huge difference if you can be relaxed when on the bike.
Also you can try fitting heavier bar ends which will help damp the vibration down a little.
How good a fit are your gloves. If they are to big they'll bunch up in your palm and this also makes life uncomfortable.
Old 22-07-06, 08:31 AM   #4
Stig
There are a number of things you can try. Shifting the levers is always the best one to start with as it costs nothing.
You could try different softer grips to reduce the vibration or different bar ends to do the same thing. Even different tyre pressures can make a difference.
Old 22-07-06, 08:33 AM   #5
markward
Also can any one comment on how noisy there engine is I've never had a v twin before and have noticed that when hot there is quite a heavy knock at idle and noticeable up to about 3000rpm. Obviously as its new I'm going to go back to the dealer just interested in others opinions....
Old 22-07-06, 08:55 AM   #6
sounds normal espesh if you used to in line 4 engines. the sv dont really smooth out til 5-6k
Old 22-07-06, 08:56 AM   #7
where in the midlands are you markward?
Old 22-07-06, 09:19 AM   #8
markward
hi I'm in Dudley. Yes i had a 600 ninja and a vfr ( v4) both were as smooth as a baby's bum and i work for BMW as a tech so I'm used to smooth engines and dont like knocking noises im sure i will get used to it .. loving the bike though...
Numb fingers. r1ck SV Talk, Tuning & Tweaking 22 14-03-09 02:24 PM
Numb Nuts!! sisk650k4 Pennine Massive 7 23-03-08 10:58 PM
Numb face andyaikido Idle Banter 3 18-07-06 04:10 PM
Numb wrists? Diveboy SV Talk, Tuning & Tweaking 22 16-06-06 06:57 AM
Numb hands Unlucky4some SV Talk, Tuning & Tweaking 11 21-03-06 11:06 PM
