After sorting out the sticking choke, and replacing the plugs my sv will start and run ok, it just will not tickover unless the choke is slightly on. I cant see any air leaks in the carb rubbers. Is it likely to be crud blocking the slow running jets? or should I be looking at another source of the problem
#2 | |
Sent from my PC NOT using any Tapatalk type rubbish!! █╬╬╬╬(•)i¯i▀▀▀▀▀█Ξ███████████████████████████████) |
Tried that but it made no difference, It did idle before i fixed the choke cable, albeit erractically. I suspect that fixing the sticking choke has thrown up another problem
The Sick Man
mabey the idle adjuster is broken
OTR: KTM 690 Duke R 2015 Full Akro SIDELINE: Kwak ZX636 A1P 2002, Red, R&G's, Yoshi, Double Bubble Screen GONE: Kwak ZX-7R P1, Full Akro, Undertray, Screen GONE: SV650S K2 Very Bruised & Without Fairing, Motovation Frame Sliders, R&G Ally Sprocket Toe Protector, HEL 2 Line Setup, GSXR K1 600 RWU Forks, Barnett Clutch & Springs, Penske 8981 Shock, Gilles Ti Rearsets, Steel Barends, Scottoiler, AFAM Chain & Sprockets, Twin FIAMM Horns, Skidmarx Bellypan, Full Micron Zeta Steel System, Cut down undertay. Forum Problems & Information / Site Suggestions |
Tickover a bit high? | krhall | SV Talk, Tuning & Tweaking | 9 | 20-05-08 05:31 PM |
tickover pin | Hazzar | Stuff Wanted | 0 | 09-09-07 04:37 PM |
missfire on tickover | 01 sv650s | SV Talk, Tuning & Tweaking | 1 | 30-03-07 05:48 PM |
Fast Tickover | Gordon B | SV Talk, Tuning & Tweaking | 6 | 26-03-07 11:35 PM |
Low Oil Pressure at tickover | SteveJWhit | SV Talk, Tuning & Tweaking | 3 | 04-05-05 10:04 AM |
