Old 22-10-09, 04:42 PM   #11
Default Re: running problem - as if running out of petrol
You can shoot some WD40 up the drain hole with the straw. Works a treat, who'd have thought it was a water-dispersant
Old 22-10-09, 04:44 PM   #12
Nick8529
Ok i will give that a go tomorow
I will keep you updated on if it works or not
Thanks for your help.
Old 22-10-09, 04:50 PM   #13
If it is the front s/plug, then make sure you get a fenda extenda for your model, otherwise you're going to have this happen regularly in the wet.
Plus its flippin scary & dangerous if the front keeps cutting in and out, as I found out the only time it happened to me
Old 23-10-09, 11:46 AM   #14
vardypeeps
Wet front plug I reckon.
Water takes a while to dissipate.
+1
Old 23-10-09, 07:50 PM   #15
boot
That's because 9/10 people don't actually know what WD40 stands for.
+1 for wet plug, I had what sounds like the same issue not so long ago. It takes a while to 'burn' it off.
Start bike and keep revs up for... a good while, and all should be swell after a bit.
Old 25-10-09, 06:55 PM   #16
MrMoonface
Had the same thing happen to me this weekend. Scary! When you've taken the plug out and dried it off try putting a bit of vaseline around the top of the plug cap to stop the water getting back in. Works a treat whilst the fender extender is on the way!!
Old 26-10-09, 01:06 PM   #17
Yup you can slather some grease around the cap to seal it.
Old 26-10-09, 01:12 PM   #18
Owenski
Cheers boot saved me posting the same link.
+1 to what most have said.
Old 26-10-09, 03:29 PM   #19
punyXpress
punyXpress's Avatar
Hesitating :
a ) Choke not fully opening - either plungers & cables need greasing OR Operator Error
b ) Carb icing - even relatively mild mornings can have this if moisture levels are right for it.
Now: Street Triple R
Old 26-10-09, 06:27 PM   #20
Nick8529
the problem seemed to sort its self out so i think the spark plug had ebough time to dry. but i sprayed some silicone spray around it when i had the lead back on to protect it but it seems to have started the problem again. I am going to take it apart this weekend and give it a proper clean and a dry. Hopefully that will sort it out.
sv running problem? any ideas Crunchy SV Talk, Tuning & Tweaking 6 31-07-09 04:27 PM
Not Starting after running out of petrol. gerbrox Bikes - Talk & Issues 4 15-08-08 10:52 AM
And you thought running out of oil was a problem... gettin2dizzy Idle Banter 22 11-06-08 08:04 PM
Odd choke/running problem northwind SV Talk, Tuning & Tweaking 13 07-06-05 11:46 AM
Starting /rough running problem Sholay SV Talk, Tuning & Tweaking 5 26-01-05 04:18 PM
