06-06-08, 09:00 PM | #1 |
Removing R&Gs to fit fairing.
Now that I've got a fairing to fit I started removing the R&G crash bungs, to discover that they are fitted with longer engine bolts to accomodate the extra width of the bracket.
I can only assume that I've got to get myself some new engine bolts from the dealer? Any idea on cost or availability? I think I could just unscrew the plastic bit and leave the bracket under the fairing? But then it would be nice to ebay the crash bungs as a usable set. |
06-06-08, 09:33 PM | #2 |
Re: Removing R&Gs to fit fairing....
If you want to get rid of the R&G's on flea bay let me know first, I am after a pair for unfaired K4
<((((((((((((((((◕‿◕) The Woozle woz ere (◕‿◕)))))))))))))))> Black K4 Pointy named Zuky, OEM belly pan, OEM hugger, OEM cowl, R&G bungs, akrapovic system, tinted double bubble Fabbri screen, tail tidy, scottoiler, alarm, datatagged, lowered seat for short ass rider named Shell. RIP PC David Rathband sad day 29/2/2012 |
07-06-08, 09:02 AM | #3 |
Replacement engine bolts are cheap enough, as they get forgotten a lot when people sell bikes with crash bungs on.
Is that bolt going into the front cylinder head mount the proper one? The curvy one uses an allen head bolt.
07-06-08, 09:41 AM | #4 |
07-06-08, 10:09 AM | #5 |
If it's any help I've still got my original bolt that you can have as have sold my sv (K6)??
Where u based? |
07-06-08, 10:26 AM | #6 | |
Yeap you will need the standard bolts, they are cheap. If you want to retain the R&G's you'll need to order the proper metal mounting bracket which holds the bung but also secures the fairing. |
07-06-08, 03:33 PM | #7 |
Thanks for the offer fibble, I'm in Plymouth. I would like to keep the R&G's if poss. Does that bracket replace the black bent fairing mount that is used OE?
Seems like a much better idea than mounting bungs onto the above mentioned bracket. I'll drop R&G an email to see if I can get those brackets. |
07-06-08, 03:37 PM | #8 |
10-06-08, 11:53 AM | #9 |
R&G say that whilst some of the fittings for the bikini faired kit and faired kit are the same, it will be cheaper to just buy the full fairing kit.
10-06-08, 06:37 PM | #10 | |
You'll never get a straight word from R&G!!! |
Removing lower fairing | Mighty Boosh | SV Talk, Tuning & Tweaking | 3 | 08-03-09 10:29 AM |
removing fairing | silent11 | SV Talk, Tuning & Tweaking | 2 | 24-03-08 08:08 PM |
removing fairing | yankeedoodle | SV Talk, Tuning & Tweaking | 2 | 27-10-07 11:09 PM |
removing fairing | yankeedoodle | Bikes - Talk & Issues | 9 | 07-06-07 05:10 PM |
Removing rear fairing | elqueson | SV Talk, Tuning & Tweaking | 15 | 14-11-06 08:58 PM |
