15-02-14, 11:43 PM | #1 |
Pointy rear caliper seal set part number?
Hi guys,
Just a quick one (hopefully). I'm after a seal set for the rear caliper on my K3 SV650S. According to http://www.bike-parts-suz.com/suzuki...ListID=3423311 the part number is 69100-04820 yet on robinsons foundry this is showing up as a rear caliper seal set for an XF650. I'm guessing the XF uses the same caliper/seals as the SV...? Just wanted to check before I order. Last edited by AkiraSV; 16-02-14 at 12:08 AM. |
16-02-14, 12:12 AM | #2 |
Re: Rear Caliper Seal Set Part Number
Yes, same caliper as umpteen other Suzukis.
16-02-14, 12:17 AM | #3 |
Okidoke, thank you!
Kawasaki 636 BH1 rear shock bottom bolt part number? | Pricey12 | SV Talk, Tuning & Tweaking | 6 | 09-04-13 09:50 AM |
Pointy Rear brake reservoir seal | DanSp | Stuff Wanted | 3 | 21-11-12 03:17 PM |
Pointy rear caliper | dirtydog | Stuff Wanted | 5 | 07-01-11 08:53 PM |
Part No. for rear caliper bolts | TheShadow | SV Talk, Tuning & Tweaking | 3 | 03-08-09 11:59 AM |
Pointy Rear caliper bolt | Brettus | Stuff Wanted | 0 | 21-02-09 02:58 PM |
