16-06-10, 06:24 PM | #1 |
What jet size
Looks like I'm not going to get to the Dyno before I go on my next track day so what size jets should I fit to an SV 650 with BMC race filter and full Akrapovic Titanium system and can?
142? 150? 155? 160? Tank is raised by an inch Last edited by hardhat_harry; 16-06-10 at 10:35 PM. |
17-06-10, 08:49 AM | #2 |
Re: What jet size
I assume you are using a BMC RS race filter with the large oval hole in the top. This is the filter supplied with the Factory Pro stage 2 induction kit and they recomend (Mikuni sizes) 162.5 front cylinder and 160 rear cylinder with competition exhaust, but warn, could vary + or - 2 sizes. So there is a start point for you, but personally there is no way I would run it at a track day without a road test or Dyno run, or both. A Dyno run will tell you if it is making good power but it won't tell you what it is like to ride on small throttle openings. Hope this helps.
17-06-10, 09:23 AM | #3 |
Re: What jet size
Richer at front?
17-06-10, 09:26 AM | #4 |
Re: What jet size
Its the standard Race not the RS and its got 137.5's in at the mo'
17-06-10, 09:28 AM | #5 |
Re: What jet size
I must admit I thought richer at the rear as it gets hotter in the rear cylinder though I have not heard of anyone till now running different jet sizes on an SV though its common on other twins.
17-06-10, 09:29 AM | #6 |
Re: What jet size
Yes, richer at front. A lot of people say richer at rear because the rear will run hotter, but it's probably to do with the dynamics of the airbox. Anyway, I trust Factory Pro on this 100%.
17-06-10, 09:30 AM | #7 |
Re: What jet size
Probably more down to airflow getting into cylinders rather than around them, it is LC motor after all.
17-06-10, 09:35 AM | #8 |
Re: What jet size
OK that sound like a plan I'll get the 160 / 162.5 and a set one size lower. At least it will be on the safe side running too rich and I can do a quick swop in the lunchtime if it bogging down.
17-06-10, 09:37 AM | #9 |
Re: What jet size
I also hear about turning the AF screw out 2.5 turns, does this work?
17-06-10, 10:06 AM | #10 |
Re: What jet size
You got some balancing gauges?
Right size? | arcdef | Helmets | 13 | 09-08-09 12:21 PM |
Size 9? | ASM-Forever | Thames Valley | 9 | 13-11-07 03:50 PM |
RST Boots size 7 | John 675 | For Sale - SV's and SV related items | 0 | 08-04-07 07:28 AM |
Alpinestars SMX-Plus Boots - White euro size: 43,US size: 9 | paulthewitt | For Sale - SV's and SV related items | 2 | 16-12-06 12:39 AM |
