Old 10-04-17, 12:43 PM   #1
muzikill
muzikill's Avatar
Default Milky fluids
Disaster.
Ive not checked the freeze plugs yet or anything else.
Old 10-04-17, 12:44 PM   #2
muzikill
muzikill's Avatar
Default Re: Milky fluids
Garaged and always changed regularly. Im losing the biking will. 😕
Sent from my GT-I9505 using Tapatalk
Old 11-04-17, 01:40 PM   #3
R1ffR4ff
R1ffR4ff's Avatar
When this happens on my old CX500s it's the water pump mechanical seal.I have a technique for replacing them without having to use the metal cup but don't know if a similar procedure can used on the SV650.
You see the technique here,
http://www.pdsrecording.site90.com/cxgl500/Mseal.html
Old 11-04-17, 03:02 PM   #4
muzikill
muzikill's Avatar
Cheers. Hopefully its this or the freeze plugs. In any case its a gasket, a full set of water pumps seals and plenty of fluids and oilf filters to flush out the engine 'if' that is all it needs.
Old 11-04-17, 03:19 PM   #5
R1ffR4ff
R1ffR4ff's Avatar
As I'm new to SVs what are the,"Freeze Plugs"?
Old 12-04-17, 09:26 AM   #6
SV650rules
@ R1ffR4ff - Freeze plugs on a car are special weak points on cylinder block (normally replaceable steel discs) that are designed to pop out if ice forms in water jacket to stop further damage from pressure of ice. I didn't know SV had them
Normally water goes milky when oil gets into it and forms an emulsion, so may be oil getting into coolant somehow, normally water pump seal or head gasket.
2016 SV650 AL7
Old 12-04-17, 11:02 AM   #7
R1ffR4ff
R1ffR4ff's Avatar
Thanks for that.I've been through a lot of water pump/cooling faults over the years and had forgotten that some engines have different designs.
On the old Honda CX500s it used to be that you had to take the engine out and remove the rear engine cover to fix a faulty Mech-Seal but using my way it can be done in-bike
Old 12-04-17, 07:33 PM   #8
DuncanC
Wouldn't a freeze plug be between the water jacket and the outside world? Why compound a frozen water jacket with contaminated oil? My money is on water pump seal.
DuncanC is offline   Reply With Quote
Old 12-04-17, 08:02 PM   #9
Taipan
Taipan's Avatar
Known as core plugs on cars...
Old 12-04-17, 08:28 PM   #10
Dave-the-rave
Dave-the-rave's Avatar
The core plugs on an SV650 are located either side of the spark plug, between the cam shafts. You have to remove the cam covers to have a look, same as when checking valve clearance.
SV650N K1
Dave-the-rave is offline   Reply With Quote
Guy makes mistake tasting bike's fluids L3nny Idle Banter 7 25-03-15 07:02 PM
Coolant fluids - what & where to get them. muzikill SV Talk, Tuning & Tweaking 1 03-05-11 10:45 AM
Suzuki sv 650 greases & fluids equivalent list muzikill SV Talk, Tuning & Tweaking 19 07-03-11 09:32 PM
The Milky Way DarrenSV650S Idle Banter 1 15-06-09 11:50 AM
Brake fluids .... More useless information Spokey SV Talk, Tuning & Tweaking 21 03-11-08 09:36 AM
