Old 21-11-17, 05:22 PM   #1
Stilo
Stilo's Avatar
Default How do these work
OK call me stupid.
I bought these stud extractors, they didn't have any instructions & I can't work out how to use them. I e,mailed the manufacturers but whilst they were happy to take my money they have not been so forthcoming with help.
There are 4 installers & 4 extractors, has anybody any idea how to use the extractor?
http://www.bergentoolsdirect.co.uk/p...ller-set-5809/
Thanks
He was a hairy handed Gent who ran amok in Kent Awhooo
Stilo is offline   Reply With Quote
Old 21-11-17, 05:37 PM   #2
Default Re: How do these work
if they are what i think they are you just pop the socket onto the stud and turn it. the concentric bearing inside grips the wall of the stud and tightens up as you turn. TBH they are fine for 'good' studs but not that good for rusted/seized ones.
two nuts tightened against each other work just as well.
Old 23-11-17, 08:37 AM   #3
Stilo
Stilo's Avatar
Thanks
There is not enough of the stud left to get 2 nuts onto or else I would have tried that first. I bought these extractors as the access is restricted (left hand exhaust clamp stud on the front cylinder) & they are slim enough to go over the stud .
Onto plan B what ever that might be
Old 23-11-17, 08:42 AM   #4
SV650rules
Bit of local heat works well with steel screwed into aluminium, the the aluminium expands more than the steel and takes pressure away from the steel thread.
2016 SV650 AL7
Old 23-11-17, 12:09 PM   #5
R1ffR4ff
R1ffR4ff's Avatar
That's why I keep one of these handy,
https://www.ebay.co.uk/itm/Jet-Nozzl...EAAOSwn5RZjqUI
Absolute boon for these jobs.Ultra directional
£6.95 ish.
Old 23-11-17, 03:15 PM   #6
Stilo
Stilo's Avatar
Thanks I was hoping to heat the stud up and then use the extractor on it while it was still hot
Old 22-01-18, 08:07 PM   #7
Stilo
Stilo's Avatar
Finally got the stud out, I took the engine to a local engineering company who puddle welded (mig) a larger size nut onto the M8 stud. Then while it was still warm loosened/tightened the stud bit by bit until it came out nice and clean. Stainless steel replacement sourced.
It was a lot of faffing about but all's well etc.etc.
Lesson learnt, be more wary and/or less clumsy then the next time i need to take one out.
Old 24-01-18, 09:32 PM   #8
They're very easy to snap, even with care
Indicators work, hazards don't work properly. DanSp SV Talk, Tuning & Tweaking 2 03-02-13 10:52 AM
a new work look Fluffer Idle Banter 20 08-11-10 10:43 PM
Anyone work for Sky? TSM Idle Banter 5 09-09-09 11:15 AM
On my way to work. neuone Photos 25 07-04-06 04:02 PM
