01-11-06, 02:36 PM | #1 |
Do I have to take off the swing arm for chain replacement?
I am already in the process of doing so but was wondering for next time if this step is really appropriate or not since it seems that i can just cut and reconnect the chain while it is on the bike.
01-11-06, 02:40 PM | #2 |
The chain will have a rivet link that can be used, if the chain is an endless one carefully removing one link using a dremmel to take off the 2 rivets on one link then run the new chain and put in the rivet link in place of the one removed.
Edit: you will need a chain rivet tool & dremmel / angle grinder for this.
Modern motorcycles are bloody brilliant, enjoy it while we can |
01-11-06, 02:41 PM | #3 |
Vipers Pillion Bitch
Cut the old chain off. New chains come with a split link. You do, however, need a chain rivetter to fit the new chain. A mechanic will do this for a fiver or so.
PS. Welcome dude!
I look good, I mean really good! Hey everyone come and see how good I look! |
01-11-06, 03:11 PM | #4 |
You will need to take it off if you want to use the super long-lasting endless Suzuki chain.
01-11-06, 03:13 PM | #5 | |
01-11-06, 04:16 PM | #6 | |
01-11-06, 07:52 PM | #7 |
great info
great info thanks for the help i am using a rk chain that isn't endless so it looks like i will be able to avoid that horrid task of taking off the swingarm, and the grotesque tool i made for that locknut already.
29-01-07, 09:09 AM | #8 |
what about using a split link?
29-01-07, 10:51 AM | #9 | |
29-01-07, 11:20 AM | #10 | ||
Cam chain replacement - is that normal? | Knaapie | SV Talk, Tuning & Tweaking | 19 | 09-11-08 10:27 PM |
chain running on swing arm? | AndyBrad | SV Talk, Tuning & Tweaking | 6 | 15-09-08 11:53 AM |
Chain & Sprocket replacement | inspectorgadget | SV Talk, Tuning & Tweaking | 54 | 27-11-07 12:31 PM |
Replacement Chain and Sprockets | sharriso74 | Idle Banter | 7 | 22-05-06 11:51 AM |
chain and sprocket replacement | sv650gerbrit | SV Talk, Tuning & Tweaking | 5 | 11-05-06 09:48 AM |
