Old 23-05-08, 03:22 PM   #1
pencil shavings
Default Chain and sprockets
Ive done a search, but nothing seems to come up with an answer saying do this!
I need to change my chain/sprokets but I dont want to take off the swing arm, so that rules out OEM. I want to keep standard gearing and want good life from it, so thats steel sprokets.
what should I get?
And it really needs to be done by next sat when we go to France
Thanks for the help boys and girls
Old 23-05-08, 03:34 PM   #2
petevtwin650
Default Re: Chain and sprokets
what should I get?
With the curvy OEM set they do include a soft link to rivet it with as well, so you could split the endless, install it and then rivet it. Don't know if it's the same with a pointy OEM set though.
Old 23-05-08, 03:36 PM   #3
rigor
It is the same with the pointy. Just cut the endless chain and use the supplied soft link.
Old 23-05-08, 04:46 PM   #4
pencil shavings
thanks, Is the OEM one the best route then? Can you get it online? I tried to google for it but could only find aftermarket ones.
cheers
Old 23-05-08, 07:06 PM   #5
dirtydog
Knob faced knobster
dirtydog's Avatar
i normally get a chain and sprocket kit from wemoto costs about ?90 or so depending on what chain you get. i normally get izumi chain as it comes with a soft rivet link and a spring link, i fit it with the spring link and ride to my normal bike shop and get them to fit the soft link they charge me a fiver or there abouts
2001 SV650 in shimmerin green, Not broken anymore
Old 23-05-08, 09:59 PM   #6
pencil shavings
Ive got these prices from www.demonbikes.com
KIT1 - Renthal Front&rear sprockets with Tsubaki X-Ring gold: ?110.40
KIT2 - Rnethal front&rear sprockets with Renthal X Ring Gold: ?124.57
KIT3 - Economy steel pattern front& rear sprockets with Tsubaki O-ring : ?83.79
Is kit3 the same thing that you get DD?
Old 23-05-08, 10:35 PM   #7
JT sprockets and tsubaki chain. Comes with a rivet link. I think mine came from B and C, recommended by spanner man anyway.
Plus scottoiler
Old 23-05-08, 10:46 PM   #8
dirtydog
Knob faced knobster
dirtydog's Avatar
have a look here, scroll down to chain and sprocket kits. I normally get the izumi chain, a few people on here don't rate tsubaki chains
http://shop.wemoto.com/index.dyn?oid=5834298
Edit: Scrap that it's Iris chains that people don't rate
Old 23-05-08, 11:08 PM   #9
pencil shavings
Is there much/any differance in the DID and Izumi chain? The kit is £10 different, worth it?
cheers
Old 23-05-08, 11:10 PM   #10
I knew that one, you get what you pay for
Also the tsubaki I'm running is one of the stupidly-heavy-duty ones to compensate for the fact that I'm very lazy when it comes to maintenence of chains.
Chain And Sprockets squirrel_hunter SV Talk, Tuning & Tweaking 10 19-05-09 10:28 PM
New Chain and sprockets? gavinsky23 SV Talk, Tuning & Tweaking 14 05-03-08 12:13 PM
chain + sprockets? lancasterlad SV Talk, Tuning & Tweaking 2 06-08-07 08:01 PM
chain and sprockets adey Stuff Wanted 4 27-11-05 01:26 PM
Chain & Sprockets BaggaZee SV Talk, Tuning & Tweaking 23 12-01-05 07:07 PM
