Old 04-06-13, 02:31 PM   #1
Nick_69
Nick_69's Avatar
Default Removing a snapped bolt?
I was tighten up the front wheel brake disc bolt, but managed to snap the bolt in half, which has left half the bolt in the slot, I was wondering what would the best way to get it out
Was SV650S K9
Now GSXR 600 K9
Old 04-06-13, 02:37 PM   #2
sniff
sniff's Avatar
Default Re: Snaped Bolt
I've got one that's stuck. So can't get the front fender out for painting. Not a happy bunny.
sniff is offline   Reply With Quote
Old 04-06-13, 02:38 PM   #3
rictus01
rictus01's Avatar
all depends how it snapped and what remains in the hub really, a pic might help.
Old 04-06-13, 04:09 PM   #4
mikerj
If you have snapped it simply through over-tightening, then drilling the end of the remains and using an 'easyout' type extractor is probably the easiest solution.
If it's snapped due to being cross threaded and being forced in anyway, then you might as well get the whole thing drilled out and a heli-coil thread insert fitted.
Old 04-06-13, 05:29 PM   #5
Nick_69
Nick_69's Avatar
Default Snaped Bolt
Thanks. It has just snapped due to over tightening
Was SV650S K9
Now GSXR 600 K9
Old 04-06-13, 06:31 PM   #6
If you drill it out properly you won't need a helicoil, drill it perfectly central a size down from whatever bolt size it is and you should be able to get remaining coils out, I've done this method many times.
Old 04-06-13, 07:14 PM   #7
+1
I chewed up the head of a S/S Pro Bolt disc bolt, drilled the head off it and then the thread, as it wasn't coming out easily.
If you use a left handed drill bit, it might help the bolt to loosen enough to grab any bit sticking out with some mole grips and extract it that way.
Snapped pinch bolt Winder SV Talk, Tuning & Tweaking 18 04-06-11 09:33 AM
Snapped engine mounting bolt. toby_smith SV Talk, Tuning & Tweaking 6 13-04-10 09:26 AM
Snapped Radiator Bolt. TheShadow SV Talk, Tuning & Tweaking 6 06-04-08 12:56 AM
99 sv650s - Snapped a bolt dhtmldude SV Talk, Tuning & Tweaking 1 05-03-08 10:41 PM
snapped a disc bolt! haggis SV Talk, Tuning & Tweaking 4 31-03-07 07:32 PM
