My Curvy unfortunately has to live outside under a cover. Due to the shocking weather It hasn't bee used for over a month. I thought I'd go out for a litlle pootle today but it refused to start
![]() Hope someone knowledgable will be along soon ![]() Oh and how exactly do you drain the carbs!? Thanks |
When you DO get it started, spit on both exhausts & establish which aint firing.
You haven't solved owt but you've got a clue where to start from.
Was: K2 naked in rapid yellow ![]() Now: Street Triple R |
To drain the carbs I think the float bowl (chamber at the bottom of each carb) should have a screw in it you can undo to drain them.
Probably worth syphoning out the fuel from the tank, and putting some high octane in. And like puny says check which cylinder and maybe try a different plug.
Now it's dark, start it up again & look for any stray sparks.
Sounds likie it could be gummed up carbs...get some fresh fuel in the tank, get the battery charged and get the engine running, see if you can go for a half-decent ride. Maybe get some silkolene pro FST in there too
My dad had a bit of trouble getting his VFR started after 3 weeks of it sitting doing nothing in a garage |
![]() ![]() Took off the tank and drained out the old fuel. looked at the drain plug as I'd read that this sometimes gets clogged up. It was fine and fortunately no sign of any rust ![]() Took off the air box and checked the carbs. Again these looked clean, no gunk or carp anywhere but gave them a shot of carb cleaner anyway. Risked it and didn't drain the carbs. Put it all back together with abit of fresh fuel and it started first time ![]() revved it a little and the backfiring started again ![]() Thought i'd go out and give it a little run to try and sort it. After about half a mile it's running like a dream again ![]() Thanks guys. As a reward for not being a nightmare I have treated him to a tank of shell V power and booked him in for a carb balance and to have the valve clearances checked |
Sounds like the water contamination mine suffered from to me. Did you drain yoru fuel into a clear container? You can see if it was water contamination then as they clearly seperate and the yellowish fuel sits on top of the clear water.
#8 | |
I'll probably stick the fuel I drained in the lawnmower. I'm sure that won't be too fussy about what petrol it gets! |
#9 |
If mower is single cylider, it'll be a 8ugger when one pot stops!
Which SV; the far better looking curvy or the badly built pointy? | starsky72 | SV Talk, Tuning & Tweaking | 33 | 10-10-11 05:43 PM |
Why does riding a bike make you want to pee so badly? | Bear | Idle Banter | 29 | 05-05-08 08:06 PM |
badly needed.right pillion peg/exhaust hanger | vzzzbuxt | Stuff Wanted | 4 | 07-10-07 08:51 PM |
Running badly in the wet | Addick | SV Talk, Tuning & Tweaking | 14 | 09-12-05 08:40 PM |
its ok to drive badly! official! | busasean | Bikes - Talk & Issues | 11 | 18-05-05 04:48 PM |
