09-06-06, 07:25 PM | #11 |
Nope But it can probably be done. The SV fuel sender is a really simple number, so if you've got a full wiring spec for the guage inuts, one of the clever people could probably figure it out.
10-06-06, 11:15 AM | #12 |
Is there anyone with a Haynes manual? I've lent mine to a friend and is not at hand, but if I recall correctly the sensor is nothing but a switch. I stand to be corrected of course. I'll get the manual tomorrow if you're willing to wait. If it's a switch the bulb should just light up, fullstop.
10-06-06, 12:15 PM | #13 |
Got a haynes manual for the curvey, the fuel sensor is listed as a 3 wire connection:
Black / White common ground then from that ground 2 seperate resistors (sensors) and an output wire for each: 1 Red / Black 1 Green / Black According to the manual if all is well the fuel light should come on for a few seconds when ignition is first turned on then light should flash when tak has around 3.5L left, and go permanently on at 1.5L left. If the above is not happening And the bulb is ok drain tank flip over and rest on cloth so as not to scratch it, remove sensor and test as follows: Connect Black/White, and Red/Black with jumper wire, with ignition ON the fuel light should flash, then stop 30 sec after jumper wire removed. Reconnect wire between black/white and red/black, and make a seccond connection between black/white and green/black with ignition ON, light should be on permenantly. 30 sec after removal of jumper wires the light should go out. This bypasses the fuel sensor so if it passes those tests ok but not when you have fuel in the tank it is probably a dicky sensor, if it does not act as described above then the fault isin the wiring of the bike or the instrument pod etc. All robbed wholesale from Curvey Haynes manual section 9.16 Oh also a little instent gaset / sealent should be used when (carefully) re-fitting sensor and the tank should be checked for leaks on re-filling... :edit: Not sure if you're on a pointy / curvey but I'd have thought the process would be fairly similar for either, things like colour of wires should not be taken as gospel on post K2 bikes though.
Modern motorcycles are bloody brilliant, enjoy it while we can |
10-06-06, 01:56 PM | #14 |
Thanks for the info Jambo.
10-06-06, 02:41 PM | #15 |
No worries, you could try tracing the 3 wires to see if you could bridge them before the sensor to save taking the tank appart... not sure if it's possible or not...
fuel sensor removal | ginger-(sv)ninja | SV Talk, Tuning & Tweaking | 1 | 01-10-07 09:58 AM |
Low Fuel Sensor For A K3 SV650 | Brucey | Stuff Wanted | 0 | 13-04-07 04:19 PM |
Just realised | Alpinestarhero | Idle Banter | 10 | 05-02-07 03:42 AM |
General bike catalyser/fuel/sensor question | Anonymous | Bikes - Talk & Issues | 2 | 01-04-05 08:30 AM |
