06-01-08, 06:09 PM | #1 |
Oil pressure light sk5
Hi me yet again with another fault....... searched for stuff on this cant believe i'm the first to have oil pressure probs but cant find nuffin....
right was on way home from asda 7 miles away and oil light came on while stood at lights at tick over..... never done this before unless i've had tickover way down and bike stalled. on the 7 mile trip home the light started to come on higher up the rev range till a got home and now it only goes out over 4k.... tomorrow i'm gonna do an oil change as normaly change oil every 1k-1.5k and not 100% sure when i last did it now the brain picking bit 1 how easy is it to check the oil pressure 2 can the pressure sender go boobs up and is there any way to check them 3 if the pumps stuffed how easy a job is it to change fix 4 any good bike shops in northeast anyone can recomend that wont ream me a new you know what thanx in advance for any help.... |
06-01-08, 06:14 PM | #2 |
Re: Oil pressure light sk5
Hopefully it will turn out to be a fault with the oil pressure switch causing the light to come on.If not you have probably destroyed your engine by riding it like that.
06-01-08, 06:21 PM | #3 |
engine still sounds ok no bangs or rattles and engine temp still normal would be just my luck at mo to of flupped it like
06-01-08, 06:29 PM | #4 |
You didn't say if you'd checked your oil level?
It's bloody risky to use it like that. You could get another pressure sensor and swap it out to see if that does it. If not the engine has a problem obviously. You'd have to be mental to use your bike for even 10 seconds until you've done this. |
06-01-08, 06:46 PM | #5 |
hi oil level still the same place it was after i did the last change thats one thing touch wood this bikes never used any oil
06-01-08, 07:03 PM | #6 |
That's something then. You're right in saying oil pressure problems are super rare, not surprised a search turned nothing up. Most oil pumps are basically a cog turning in a housing, not much to go wrong as long as nothing gets blocked or leaks and it sounds like you look after your machine. I'll lay serious odds it's the sensor but wouldn't use it again till I knew it for sure. Is it easily accessible on an SV (I not got one)?
06-01-08, 07:39 PM | #7 |
06-01-08, 07:58 PM | #8 |
now that is random its the page before the speedo sensor that was my problem last week lol
8.36 oil pressure sensor 8.37 speedo sensor i'm guessing it would be a good idea to get the new sensor before i oil change it to save wasting oil |
07-01-08, 12:19 AM | #9 | |
Graham |
07-01-08, 09:52 AM | #10 |
Flickering oil pressure light | jamesw1024 | SV Talk, Tuning & Tweaking | 4 | 03-04-09 09:41 PM |
2 blown brakes light bulb's and a parking light. | Grinch | SV Talk, Tuning & Tweaking | 4 | 20-10-08 11:08 AM |
Oil pressure warning light! | mjf65 | Bikes - Talk & Issues | 8 | 23-07-07 10:00 AM |
clear tail light / stop light Lens for sale | SVTONYB | For Sale - SV's and SV related items | 7 | 20-05-07 04:55 PM |
sv650 99-02 rear light+indicators+numberplate light | andyrs | For Sale - SV's and SV related items | 3 | 29-09-06 10:59 AM |
